Mil Not Coming On
Old Jan 2, 2006 | 09:53 PM
ramsfan's Avatar
ramsfan
Mil Not Coming On
My 96 F-150 Failed Emisions Test Becaues The Mil Doesnt Come On When Engine Is Off And The Key Is On. Any Suggestion On The Reason For This Or How To Fix
Old Jan 2, 2006 | 11:21 PM
smecomark1's Avatar
smecomark1
Question
Give me another hint, what is the MIL?
Old Jan 3, 2006 | 06:33 AM
jroehl's Avatar
jroehl
I think he's referring to the Check Engine Light. Other vehicle manufacturers refer to it as the "Malfunction Indicator Light", or MIL. On Fords, it's a CEL.
Jason
Old Jan 3, 2006 | 12:30 PM
andym's Avatar
andym
If he's talking about the CEL, then I would first suggest checking the bulb.
I've never heard of failing emissions testing because the bulb was burned out. What **** state do you live in?
Try taking it to another emissions facility?
Old Jan 3, 2006 | 01:10 PM
subford's Avatar
subford
OK, your Malfunction Indicator Lamp (MIL) as FORD calls it in their manuals.
It took me a while to come up with what they were talking about when they call it CEL, maybe a non-FORD name.
It is comes on with the other indicators and shares a common 10A fuse in the on position before you start the engine. Do the others come on? If so check the Lamp, if not check the fuse.
It is grounded by the PCM to turn it on.
Old Jan 4, 2006 | 08:06 AM
EPNCSU2006's Avatar
EPNCSU2006
They check the bulb here in NC on all OBD-II vehicles. There's no sniffer test, so all the computer stuff has to be working correctly, including the check engine light. Taking it to another testing location isn't going to do any good. Everything with OBD-II is on the computer and is linked by VIN, so there's no getting around passing the test. Nothing **** about that. They just stopped sniffer testing pre-OBD-II vehicles, but even when they did, they never checked for codes or check engine light or anything. As long as it passed the sniffer at idle, they didn't care.
Old Jan 4, 2006 | 11:43 AM
andym's Avatar
andym
It just seems like a nitpicky thing to fail it because the bulb's out. But if they're not doing a sniffer test at all, then I guess they need some measure to make sure it's running clean.
In CA, they put every vehicle on a dyno. Garages here spent millions of dollars because every smog shop needs a dyno.
Old Jan 5, 2006 | 09:28 PM
ramsfan's Avatar
ramsfan
96 and newer get hooked up to comp older still uses a dyno. thanks i will check the bulb ,but the check engine light passed with engine on thats why i didnt think it was the bulb. and yes mo is a f--ked up state. thanks again i will post if the bulb does the trick
Old Jan 5, 2006 | 10:10 PM
subford's Avatar
subford
Are you saying mo as in Missouri?
Old Jan 5, 2006 | 11:10 PM
smecomark1's Avatar
smecomark1
I did see the "Check Engine Light" Identified as "MIL" on the fordfuelinjection.com ECC diagrams, never knew that's what they called it...
Old Jan 6, 2006 | 07:00 PM
ramsfan's Avatar
ramsfan
Yes Mo Is Missouri. And It Was The Bulb $o.69 At The Dealer. Took It Back For Testing Passed No Problem.
Alta
Sep 28, 2013 04:22 PM
mwh
2004 - 2008 F150
Sep 7, 2004 08:32 PM
Mil1ion
21
Nov 9, 2002 01:15 AM
Mil1ion
Jul 8, 2002 07:50 AM
Mil1ion
Jun 21, 2002 11:29 PM
