2000 Explorer 4WD Problem
Old Jan 1, 2006 | 03:21 PM
ptwohey's Avatar
ptwohey
Unhappy 2000 Explorer 4WD Problem
My 4WD is stuck in high 4WD. Low works fine. When in auto mode it does not drive the motor to the auto position. Tried a motor no help. Switch ohms out fine. When I manually put the transfer case in the auto mode the truck does not move, but even with the motor unbolted from the case it does not drive to the auto position.
Any ideas?
Old Jan 2, 2006 | 07:27 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Jan 2, 2006 | 08:09 AM
blk2000stang's Avatar
blk2000stang
I have a similar problem in my 98 EB Explorer. It stays in 4wd high or 4 low but won't go to auto. I put in a new transfer case motor and it still does it. Now it has a problem of grinding and no reverse. If I take the t-case motor off and realign it, reverse works until I put it in 4wd low, then I lose it again and have to repeat the process. Could it be a bad transfer case, or is my wiring messed up on the t-case motor (I wrote down what colors to swap and there places). Do you have any reverse problems?
Old Jan 2, 2006 | 11:27 PM
ptwohey's Avatar
ptwohey
4Wd problem
I have no reverse problem. When I take off the motor and drive, the motor does not go to the auto mode. Something is telling it to stay in 4WD high. Also when I put the transfer case in the auto position with the motor off the truck does not move.
Old Jan 4, 2006 | 04:25 PM
blk2000stang
Same here. If I leave the motor hanging and put the transfer case in auto, the truck doesn't move, only the engine revs.
Old Jan 5, 2006 | 10:10 AM
ptwohey's Avatar
ptwohey
Smile Explorer 4WD Problem Fixed
Fixed!
The motor only drives the transfer case to 4WH or 4WL. The automatic part is operated by clutches in the transfer case driven by a magnetic coil from the electronic module. [ thats the single brown wire going into the case]. When one of the speed sensors senses a slip by no movement of the driveshaft in the front or back wheels it sends a voltage to the coil to engage to clutch. So when in Auto you should have no power at the brown wire when you truck is standing still.
Put your truck up on stands and see if all wheels move. Mine did. Turns out my clutches were locked or welded together. Replaced transfer case and all is well.
Even after replacement my front wheels still move somewhat but I think the case needs some front wheel drive sensing to operate auto 4WD.
If you can turn the back wheels or front by hand and the others turn and you can not hold them still I think you have a case change.
Ford made 8 different cases for explorer. The junk yard will need the case # on the tag on the case. Mine was YL24-AA.
Hope that helps.
Old Jan 5, 2006 | 01:58 PM
blk2000stang
Thanks for the info. Do you think the problem could just be replacement of the speed sensors?
Old Jan 5, 2006 | 04:04 PM
ptwohey's Avatar
ptwohey
4WD problem
I think if you had a faulty sensor that you would have a fault on the dash.
Do what I said before with the motor disconnected. If you have no voltage going to the coil then the front wheels should not be engaged.
Old Jan 5, 2006 | 05:04 PM
68 351 bronc's Avatar
68 351 bronc
How much for a salvage yard T-case? Was it rebuilt and did they offer a warranty?
Old Jan 5, 2006 | 08:26 PM
ptwohey's Avatar
ptwohey
Mine was 450.00 with 100.00 core and 2 months warranty. Next week I'm going to open up the case and see if I can buy the parts to fix it. Don't want to spend another 450.00 in 3 months if this one dies.
troverman
2015 - 2020 F150
48
Oct 18, 2023 01:04 PM
rrthor
Oct 19, 2016 05:30 AM
agsmv1
Jun 4, 2015 02:45 PM
joesplas
Dec 31, 2007 01:22 PM
pablocruz69
1983 - 2012 Ranger & B-Series
Dec 28, 2006 08:04 AM
