bord warner 1356 t-case
Old Jan 1, 2006 | 01:53 PM
aprice's Avatar
aprice
does anyone know where i can find a good rebuild manual or somthing similar for a borg warner 1356 t-case. i have a chiltons or haynes book but not satified for the details and level of information given by it
Old Jan 1, 2006 | 07:09 PM
witdog2020's Avatar
witdog2020
What do you need?
Its pretty self explanatory when you break it open, slip yoke or flange rear output shaft?
Anyway get the proper torx head, set T/C on the mounting face side down.
You will have to pull Flange nut and flange it has one.
Pull all 24 or so torx screws.
You will need 2 pry bars to split the case.
after you have it split you will need external snap ring pliers
then you can remove chain and sprockets for replacement also replace pin and pump while rebuilding, look for wear oh shift fork.
Also is this ESOF or MSOF?electric or manual shift T/C
Old Jan 1, 2006 | 09:22 PM
aprice's Avatar
aprice
i have the manual shift case. though looking at it, if one really wanted to you could change it over from manual to electric or visa virsa, and then i have the slip yoke.
does anyone know if the driveshafts changed in lengh from the slip in or bolt on
a friend found a t-case for me for cheap but it has the flange instead of a slip yoke
Old Jan 2, 2006 | 09:44 AM
witdog2020's Avatar
witdog2020
It can't be switched from manual to electric
Because they use different shift cams, You may be able to convert the slip yoke to flange style it would be close to the right length you would have to measure to be for sure. Or go find the right drive shaft. These are very easy to rebuild with the proper tools.
Also some of the tail housings were shorter, Do you have the model number and build date from the stamped tag?
I have a few of these where abouts are you from, you could PM me to not give that info publicly.
Old Jan 2, 2006 | 09:50 AM
witdog2020's Avatar
witdog2020
Check this link:
http://www.technicalevolution.com/borg1356.htm
Old Jan 2, 2006 | 08:21 PM
big4rd's Avatar
big4rd
I bought a Helms manual for my 95 4x4 CC diesel. Very detailed and complete. While I was putting in an LUK sm F/W, went ahead and did a rebuild on the 1356. You will need good snap ring pliers as witdog said.
Old Jan 3, 2006 | 11:10 PM
aprice's Avatar
aprice
will a warner 1345 bolt directly in place of the warner 1356?
Old Jan 4, 2006 | 08:31 PM
witdog2020's Avatar
witdog2020
Nope, different mounting pattern
Old Jan 4, 2006 | 09:17 PM
aprice's Avatar
aprice
ok thanks i kinda figured but thought i's ask
Old Jan 4, 2006 | 09:53 PM
witdog2020's Avatar
witdog2020
Pictures of 1356
I put pictures of the 1356 in my gallery, The T/C that would bolt in your truck I believe is a 4406, you have to change the 2 hole linkage rod to the longer one,and may have a drive shaft mod. Its a lot heavier T/C with aluminum case instead of Mag.
Armytruckchuck
Feb 20, 2016 10:05 AM
Gear619
Feb 23, 2015 11:06 PM
bronco 71
Offroad & 4x4
Jan 30, 2008 05:14 PM
jrv6a
1978 - 1996 Big Bronco
Sep 23, 2007 01:04 AM
str8six
Dec 27, 2002 09:38 AM
