4x4 axle combos?
Old Feb 15, 2009 | 11:59 PM
CowboyFromHell's Avatar
CowboyFromHell
4x4 axle combos?
I pulled an axle set out of 1974 F250. Its a rear Dana 70. The front is a HD Dana 44 low pinion, open knuckle, and disc brake, both axles have 4.10 gears. With the help of 75F350 it is determined that the front axle is most likely out of a '76. Were these axles ever paired together from the factory or was the front just swapped in? Thanks
Old Feb 16, 2009 | 12:31 AM
unrulee's Avatar
unrulee
Doubtfull, but I'd be happy, that truck should have had a D60 in the rear stock, a 70 is definitly an upgrade.
Old Feb 16, 2009 | 12:37 AM
Ronzi's Avatar
Ronzi
From everything Ive read the 70 came in 2 wheel drive F350's. The 4wd F250 & F350's had Dana 60's in the rear. I would think the 44 or low pinion 60 came in the front of early 70's trucks but not open knuckles disk brake versions.
Old Feb 16, 2009 | 01:05 AM
Jermafenser's Avatar
Jermafenser
Someone swapped in the rear.
D70 is for 2wd & heavier duty trucks, like chassis & cabs.
D60 rear for 3/4 tonners with 4WD. Dana 44 or 60 front. That's all you get in a 3/4 tonner.
Old Feb 17, 2009 | 09:59 PM
CowboyFromHell
Was a posi or locker in the rear a factory option? Because that Dana 70 has one in it
Old Feb 17, 2009 | 11:07 PM
75F350's Avatar
75F350
Which does it have? Locker or Limited slip?
Pull the cover off of it, and post a pic. These are easy to verify.
The factory axles did not have a "Locker", these are not typical factory options, ever. (for this era).
Many LS units are mistaken for lockers and are just limited slips.
(BTW, posi traction is a GM term) Fords use limited slip diffs. I know splitting hairs, but you know...........
Old Feb 18, 2009 | 12:00 AM
RVDan's Avatar
RVDan
every 3/4 ton truck with a divorced transfer case I've ever seen had the low pinion disk brake Dana 44
Old Feb 18, 2009 | 12:03 AM
75F350's Avatar
75F350
Then you have not seen a 75 or older F-250 with an original front axle.
The 76 truck was when the big change occurred. The 75 and older trucks came with low pinion axles with drum brakes.
Old Feb 18, 2009 | 06:31 PM
CowboyFromHell
Ok i put the pic of that limited slip/locker in my gallery. Take a look and tell me which it is please.
Old Feb 18, 2009 | 06:56 PM
Jermafenser
Rear is a Dana 70, all right.
Front looks like a 44 to me.
But hell, that's one sorry suspension.
Old Feb 18, 2009 | 10:02 PM
CowboyFromHell
How is it sorry?
Old Feb 18, 2009 | 10:13 PM
zak8tac's Avatar
zak8tac
I think that is probably limited slip, in your pic you have the diff turned 90 deg off for me to tell. I know it doesn't look like my detroit locker does though.
Old Feb 18, 2009 | 11:47 PM
m j's Avatar
m j
it isnt a detroit and it isnt a powerlok
looks open to me but I guess it could be a traclok
Old Feb 19, 2009 | 02:45 AM
75F350's Avatar
75F350
I dont see a gallery. No pics at all. Says that "user has not created a gallery"
Maybe a link????
Old Feb 19, 2009 | 02:46 AM
m j's Avatar
m j
look in his profile, it appears on the right side.
I thought that was odd too but I found it the long way
