General Automotive Discussion
96 windstar throwing code
Old Dec 30, 2005 | 09:17 PM
kermit's Avatar
kermit
need some help. i have a 96 windstar that has the 3.8 in it. sometimes it throws a p0301, cylinder 1 misfire code, and stumbles all over itself. then if you rev it to about 1500 for a few seconds it comes out of it, cel stops blinking and stays solid. it will sometimes go for months at a time without happening, then start happening every few days. very intermittent. only usually happens when starting the engine, if it is already running it usually doesnt happen, but has a couple of times.
leaving for deployment next week, would like to get this resolved before i go if i can so i dont have to worry about paying a mechanic while i am gone.
thanks,
jamie
Old Dec 30, 2005 | 10:32 PM
Monty06's Avatar
Monty06
check your plug to see if you have a loose tip.
and would be great to pull codes on the van.
Old Dec 30, 2005 | 11:31 PM
kermit's Avatar
kermit
i did, p0301, cylinder 1 misfire
Old Dec 31, 2005 | 12:15 AM
Monty06's Avatar
Monty06
ah i see
let me check it out be back in five
Old Dec 31, 2005 | 12:21 AM
Monty06's Avatar
Monty06
have you done any timing work to it
or change spark plug wires might be placed wrong.
Old Dec 31, 2005 | 01:33 AM
kermit's Avatar
kermit
nope, havent touched it. just started doing it awhile back.
Old Dec 31, 2005 | 06:54 AM
Rockledge's Avatar
Rockledge
Have you pulled the #1 plug and looked it over? Have you tried changing out the plug? You can also try swapping plug wires around to see if it's related to the wire.
A worst case scenario which has to be kept in mind is a leaky headgasket, those 3.8Ls are pretty well known for that. Losing any coolant lately? Do you get the sweet stench of coolant when you first start it and the engine is stumbling? White lingering smoke out of the tailpipe?
Old Dec 31, 2005 | 12:19 PM
kermit's Avatar
kermit
no, no smoke out the tailpipe, no oil in water, no coolant smell. i am thinking i will change out plugs and wires and see if it happens again.
