Bronco II Ford Bronco II
Cone intake.....PS91 coil
Old Dec 30, 2005 | 11:58 AM
broncobillyII86's Avatar
broncobillyII86
Has anyone ran a cone filter straight off the intake pipe going to the engine ...I was hoping to do this and take that box right out of there .....and does anyone know if the Crane PS91 coil will go on a 2.9 ok ...Not to much spark for the TFI to handle, stock ignition on her. what are your guys feeling on flex fans do they really increase coolness and what size max could I get away with in my BII ....2.9 engine compartment ....TR
Old Dec 30, 2005 | 07:34 PM
bronocIInoob's Avatar
bronocIInoob
there is a system for cold start up on the bronco II that has a heat proof tube going from the manifold to the air box with a computer controlled vavle to decide when to acutate it depending on where you live would matter in removing it if you live at areas where it gets to freezing temperaters i would suggest to leave it on and put get a high flow filter in the box as a direct replacement for a stock filter ethier way you would expect to have longer engine warm up times , and have the computer sending you an error code sence your removing a computer controled device
Old Dec 31, 2005 | 03:54 PM
Ken00's Avatar
Ken00
The warm air control valve is activated by a bi-metal valve so the ECU won't know. You will have longer warm-up times, a lot of people remove them. Make sure you plug the vacuum port.
Old Dec 31, 2005 | 07:31 PM
broncobillyII86
Where is that vacuum port located Ken, off of the air box....TR
Old Jan 1, 2006 | 02:02 AM
Monty06's Avatar
Monty06
at the top of the box
Old Jan 1, 2006 | 06:19 PM
Ken00's Avatar
Ken00
The vacuum line originates at the intake manifold, the same T that the MAF uses.
Old Jan 1, 2006 | 07:20 PM
broncobillyII86
Thanks guys ....
dmack91
Nov 14, 2012 12:56 PM
Supermarkers
1997 - 2003 F150
Aug 25, 2010 06:47 PM
fordtrucklover94
1983 - 2012 Ranger & B-Series
Sep 17, 2004 12:44 PM
4.9LFord
Aug 12, 2004 07:11 PM
BroncoIIMan
Bronco II
25
Feb 19, 2004 05:51 PM
