289 Starter Question
Old Nov 13, 2012 | 03:53 PM
dmack91's Avatar
dmack91
Can anyone confirm if I can just swap nose cones on the starter motor I have? I have a starter for a manual (short nose) and need one for a C4 (long nose cone). Not sure if the armature shaft is longer, or if the housing is just shaped differently.
I know I should just buy a new one, but I am just trying to see if the engine that came in my truck will run or if I have to do a complete rebuild or swap. Should be able to get a nose cone from a local yard cheap if it will work.
Thanks.
Old Nov 13, 2012 | 09:51 PM
ben73058's Avatar
ben73058
Bump for you Dmack - see if someone can answer your question.
Ben in Austin
1950 F1
Old Nov 13, 2012 | 09:58 PM
MCarlson's Avatar
MCarlson
My mechanic buddy says the shaft is longer so swapping out the nose itself wouldn't work.
Mike
Old Nov 14, 2012 | 02:38 AM
dmack91's Avatar
dmack91
Mike,
Thanks for the help. Thought that might be the case, but thought I would check.
Old Nov 14, 2012 | 08:17 AM
jim collins's Avatar
jim collins
You can get shims at NAPA, about 1/4 " thick, i used one once just so i could use a new starter that was for an automatic on a standard set up. Saved me from buying another new starter and having to let it just lay around. It was a 289 engine.
__________________________________________________ ______________________________________
OOps, i read your post wrong, i see you need to go the other way, can't help on that other than searching for another starter. Sorry.
Old Nov 14, 2012 | 12:56 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by dmack91
Mike,
Uh huh...
When you get your C4 starter, measure the two armatures. I'll betcha they'll be the same length since the parts catalog lists the same DOAZ-11005-A armature for both 1963/68 289 A/T & M/T.
How many mechanics in today's world would know about armature lengths for an engine last used in 1968? How many would have Ford parts catalogs?
MannyC750
Aug 6, 2019 08:46 PM
desertwest
Jun 20, 2007 11:05 PM
schlager
May 15, 2006 10:37 PM
chopper10
Sep 18, 2004 07:13 AM
