Sponsored by: Auxito
Quick Front Rotor Question
Old Dec 28, 2005 | 08:42 PM
ZoomingM3's Avatar
ZoomingM3
Question Quick Front Rotor Question
I have a 2002 XLT 4X4 (5 lug) I'm planning on replacing the front rotors. My question is, do I have to remove the spindle (35mm) nut to get the rotor off?
Thanks
Old Dec 28, 2005 | 09:40 PM
dlorenz's Avatar
dlorenz
I've not looked at a 4x4, but my '97 2x2 does require removal of the spindle nuts to remove the rotor - if this is the case, repack the bearings and replace the seals.
Old Dec 28, 2005 | 10:35 PM
7700Rob's Avatar
7700Rob
No, Just take the wheel, caliper and bracket off. Then the rotor is separate from the hub. 4X2's have a hub and rotor assembly 1 piece. If it's froze to the hub, get a bfh and swing it like a baseball bat. Or if you have one big enough, a jaw puller will do it, but I wouldn't draw it against the axle end. Good luck.
brianheard
1997 - 2003 F150
May 24, 2011 07:46 PM
hydrosmith
Nov 29, 2010 09:28 AM
KillerF250
Apr 26, 2005 05:10 AM
ZoomingM3
1997 - 2003 F150
Dec 21, 2004 09:27 PM
