2002 explorer cd error
Old Dec 28, 2005 | 07:26 AM
naillady19's Avatar
naillady19
Help,Having problem getting cd to open to unload or load,it`s a 6 changer.This happened once before and opened on it`d own.But this time it isn`t working.Would someone out there know of how to fix problem.
Old Dec 28, 2005 | 07:40 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Dec 28, 2005 | 07:02 PM
Gwala's Avatar
Gwala
I have intermittent problems getting a cd to unload, and in that state it wouldn’t load either.
The problem seemed to be that the cd didn’t quite clear the top of the slot on its way out.
If I carefully slipped a flat metal object (like a knife tip) under the top lip and over the top of the cd and gave it a little bit of a lever, it would then spit the cd out.
It has happened to me three times in the last three years and I have never been able to see why it was doing it - but forcing the cd edge down to clear the top of the slot always worked.
After that it would load and unload just fine – go figure.
Old Feb 25, 2006 | 03:10 PM
pjf4263's Avatar
pjf4263
i had the same problem and took the radio apart and fixed it myself. i have never done anything like this before and it was extremely easy. first remove the stereo from the dash. on the the right and left hand sides of the stereo there are three gold screws with the star heads. i didn't have any star drives, so i just used a small flathead that happened to fit just perfect. you only need to remove the top two screws on each side, which are the same size. the bottom screw takes a smaller head, and doesn't need to be removed. you then need to remove the two wiring harnesses connecting the cd changer to the rest of the radio. the small one pulls off easily from the cd side(not the radio side) and the on the larger one, you have to pull down the lip of the white plastic connecting piece on the cd side. then you will have the cd changer completely separated from the radio. there are 5 phillips head screws(3 on one side, 2 on the opposite side, and one on the back) that need to be removed to be able to take off the top metal cover. once the cover is removed, you have full access to the changer mechanisms. the problem with my unit was that the plastic rod keeping the cd trays alligned was bent. i fixed mine by bending the rod straight with my fingers. i also remove all of my trays to make sure they were all ok and clean. the trays are only held down by three springs. i used fishing line and tied one piece of line to the loop on the top end each of the springs. this way when i went to put the springs back on, i just had to pull on the fishing line and put the loop on the spring back on its hook. with all three springs detached from the top hooks, all the trays and the metal tray cover will come right off. you might have a little difficulty with the tray that is currently being held by the changer, but if you will look at it closely, you will see how to get it out as well. when putting the trays back in, make sure the one that the changer is grabbing is installed correctly. it is easy to see how this is supposed to be done.
the way i figured out my problem was by removing the cover to the cd changer, then plugging it back into the truck and watching what was going on. my top two trays would not go back down onto the plastic guide rod. instead, they would get stuck on top of it. i watched it several times to see which direction it was missing by, and then bent the rod with my fingers to compensate. now it works perfectly. if anyone has any questions, email me at my user name at hotmail. hope this helps.
lurch16
Feb 27, 2015 02:21 PM
luvskoolalot
Jun 5, 2013 10:30 AM
beartracks
Feb 21, 2013 05:20 PM
vinny8
Oct 24, 2011 03:35 PM
smoore79
Oct 22, 2008 02:32 PM
