yes i have always read you need the most capacity stand you can find... and dont even try to turn it bottom side up with the heads on or you engine will fall...fwiw.
I bought one from Tractor supply co. for $80.00 that will. Its rated for #1400 put a 7.3 in it was a load but held up. I put a jack stand under front of engine for safty.
