Engine Stand
Old Dec 27, 2005 | 10:21 AM
jimkidd's Avatar
jimkidd
Arrow Engine Stand
Does anyone know of an engine stand that will hold a 7.3L PSD? Pictures would be nice.
jimbo
Old Dec 27, 2005 | 11:13 AM
l-m tech's Avatar
l-m tech
have been buying stands from places like autozone or orielys.usually buy a stand with 1200 to 2000 lb capacity.still hard t5o turn engine over
Old Dec 27, 2005 | 11:47 AM
1997F-350's Avatar
1997F-350
yes i have always read you need the most capacity stand you can find... and dont even try to turn it bottom side up with the heads on or you engine will fall...fwiw.
Old Dec 27, 2005 | 04:47 PM
jimkidd's Avatar
jimkidd
I need some pictures of one that will hold the weight. I can build it if I can see one.
Old Dec 27, 2005 | 04:53 PM
ford390gashog's Avatar
ford390gashog
oh the cheap approach. i will find one
Old Dec 27, 2005 | 05:11 PM
jimkidd's Avatar
jimkidd
Not cheap, inexpensive.
Old Dec 27, 2005 | 05:14 PM
ford390gashog
just make sure your welds are good. all that supports the enigne is that 1 weld that attaches the neck to the base.
i use this one runs 100-120.00
Old Dec 27, 2005 | 05:15 PM
ford390gashog
that is just a cherry picker with the boom removed and a engine stand bolted to it.
Old Dec 27, 2005 | 05:28 PM
jimkidd's Avatar
jimkidd
i use this one (deleted pic, jimbo) runs 100-120.00
Will that hald a 7.3L?
Old Dec 27, 2005 | 06:24 PM
ford390gashog
it will hold 2k no problem. the psd is only 1100 or so
Old Dec 27, 2005 | 07:31 PM
jimkidd's Avatar
jimkidd
Can you get a couple more angles on that?
Old Dec 27, 2005 | 08:28 PM
Poohbear's Avatar
Poohbear
Smile
I bought one from Tractor supply co. for $80.00 that will. Its rated for #1400 put a 7.3 in it was a load but held up. I put a jack stand under front of engine for safty.
Old Dec 27, 2005 | 09:57 PM
jimkidd's Avatar
jimkidd
You got a part # for that?
Old Dec 28, 2005 | 08:18 PM
Poohbear's Avatar
Poohbear
Smile
Sorry for the long delay , no I dont have a part# but they only have 2 different ones the other was lighter weight.
Old Dec 29, 2005 | 06:13 PM
jimkidd's Avatar
jimkidd
I saw that stand from TSC. Are you sure that will hold a 7.3L?
