gear changes
Old Dec 27, 2005 | 07:51 AM
bass2catch's Avatar
bass2catch
Smile gear changes
i have a 1996 f150 4x4 with a 300 six and 308 gears .i pull a 16 ft horse trailer witch weighs 4000 pounds without horses .has any one regread if so to what ? i am thinking about 3.73 .the truck handles the load very well but its hard on hills some i have to drop to 2nd gear .i know i shold move up to a f250 but mine is paid for and it runs great .love the 300 ..
Old Dec 27, 2005 | 08:02 AM
The SnoMan's Avatar
The SnoMan
I pulled a horse trailer for many year before I got out of them. I would say 4.10 minimum here. Do not let the high numbers scare you because you still have OD. I think it would be the best match for your load because you really at at the limits of your towing abilty even with a 4.10 because load horse trailer can get quite heavy. I used to tow them with V8's and 3.73,s and 4.10's with no OD either. Below is a link at a axle ratio and tire size calculator.
Click Here
Old Dec 27, 2005 | 09:25 AM
RTM's Avatar
RTM
I agree with The Snoman. 4.10 gears all the way and if you do the math the 4.10's won't change the rpm much from 3.73 gears. With the 4.10 gears the motor will work less and so will the trans which will only add to the life of them.
Old Dec 27, 2005 | 11:01 AM
MBBFord's Avatar
MBBFord
4.10s would be like running 3.73 with no overdrive.
If you haul it freqently then go 4.10s, but if you only haul every now and then and travle the highway alot then 3.73 would be good to go with.
You would have to regear front and rear diffs and that's no cheap bit.
Expect to pay someone $800 tops, a axle(depending if you want any lockers or limited slips while your in there).
Old Dec 27, 2005 | 11:25 AM
mmbintn's Avatar
mmbintn
800 an axle?!?!? your crazy. You could have both front and rear done for less than that. I would say 800 total if you put a cheap locker in the rear too.
Old Dec 27, 2005 | 11:32 AM
RTM's Avatar
RTM
It all depends on where you go and who you know. I repaired a full size bronco for a guy that was qouted $1100 to rebuild the front axle and the problem was not in the gears. His auto hubs failed. Needless to say the repair was much cheaper than his rebuild qoute.
The front axle does reqiure a bit more labor than the rear.
I am currently rebuilding a 10 bolt for a customer and the price is just under $500 and parts are almost $300 and we have the cheapest labor rate in town and do more work than Firestone down the street from us.
Old Dec 27, 2005 | 11:39 AM
MBBFord's Avatar
MBBFord
Well, the best place around me charges about $300 a axle for labor, and I'm going to install gears and lockers, and they'll charge me about $800.
As far as my rear, I have a 9", so I'll just buy a new third member for about $600 shipped to my house with everything including a detroit locker.
Old Dec 27, 2005 | 11:56 AM
T.R.Bauer's Avatar
T.R.Bauer
Hey guys,
It also depends upon what you do. Low cost ring and pinion changes are normally low cost because you just got your old used pinion bearings reinstalled. Also, it is very likely that you will get your old tired carrier bearings put back in too. I personally have no problem putting the old bearings back in, but I always inform the customer that he is saving money in the short term. I have done a lot of differentials and I would say that 300 dollars is right on par for the rear end using your old bearings and a customer supplied gear set. However, I'd say 400-500 dollars is more reasonable for the front. You likely need have your hubs cleaned up and the bearings repacked. Also, I bet you could use some front brakes. I personally would do all of it if it has been a while. Do note: if you do brakes don't let them charge you full price. They have to take everything apart anyway to change your gear set. Some shops "forget" that they are double charging with labor on this one. Good luck, hopefully you will have no whines when done.
Old Dec 27, 2005 | 12:14 PM
bass2catch's Avatar
bass2catch
i onle haul about every other weekend for 20 to 30 miles .but i would like to go farther with more ease .if i am on the interstate i can run 5th gear some but mostly 4th .
Old Dec 27, 2005 | 12:33 PM
T.R.Bauer's Avatar
T.R.Bauer
In most cases it is better to tow in 4th gear anyway. For one, in fourth gear no power is going through any of the gears in your transmission. In fifth, you go through your input gear, your cluster gear, and then your dinky overdrive gear. Another benefit about 4th gear is your truck likely runs cooler AND you probably are running at a more efficient RPM when you are towing. In fact, I bet you would get better fuel economy in 4th gear when you are towing your trailer. Good luck with your gear swap.
Old Dec 27, 2005 | 06:07 PM
The SnoMan's Avatar
The SnoMan
I would still do 4.10's especailly since you have a stick as it will ease strain on clutch and tranny too while towing and make it about as good a tower as possible for that truck.
Old Dec 28, 2005 | 06:16 AM
bass2catch's Avatar
bass2catch
when i am parking,turning around or pulling out on a steep hill i put the transfer case in 4 low but the hubs are not locked in .this helps with clutch strain .i dont know about the 4.10s because the truck will be driven about 30 miles a day to work .i was wondering if anyone has changed to 3.73s and what the results were .
Old Dec 28, 2005 | 10:44 AM
T.R.Bauer's Avatar
T.R.Bauer
What is wrong with 390s?
Old Dec 30, 2005 | 06:01 AM
bass2catch's Avatar
bass2catch
i have talked to a local axle shop they said $1350 for both ends including parts also he said they use new bearings and dana brand parts . and a 6 month warrenty 4.10 and 3.73 are the same price .i guess i will put in a tack in the truck to find the rpms and do the math .the shop guy thinks with the 5 speed i would be ok with 4.10s. but i wounder how that would be for driving every day..........thanks for all the help
also i am thinking of going to 31.1050 tires i have 235 now .
Old Dec 30, 2005 | 06:22 AM
The SnoMan's Avatar
The SnoMan
Not a bad compromise if they are offered but you want a quality gear like a Yukon or Precision not a Richmond. If this was a older truck witthout OD I would say a 3.73 but with it have OD, a deeper gear is better and will reduce clutch strain too as current trany lacks granny gears. When you have to use low ramge on a hill that confirms that truck is geared way too tall. A 4.10 would fix this and yet still give you about 2200 RPM in OD at 65 with stock tires. If he has larger than stock tires, this is all the more reason to go with 4.10's too.
