'76 steering column electrical
Old Nov 30, 2001 | 07:14 PM
TCTOOL's Avatar
TCTOOL
Is there some kind of nuteral safety switch in the column that will kill my starter? I just tried to repair a sloppy column and I removed all of the wireing. I cut the harness at the wheel and plan to replace it. When I tried to re-start, no start. Is there a way to start it temporally by spliceing until I can get a new harness. I have a Haynes with wireing diagrams, but I'm no electrical engineer.
Old Nov 30, 2001 | 07:42 PM
77 steve's Avatar
77 steve
I'm alittle confused. Are you replacing the wiring harness or is there a mechanical problem with the column. I would connect all of the wires you cut back together if you haven't already for starters. Your nuetral safety switch is located on top of the coluumn not far off the floor. The easy way to find it is to start at the floor and run your hand up on top of the column until you find it. What could have happened is the pointer that operates the switch may have popped off and is not triggering the switch. If you see a small metal pointer on the floor of your truck you found your problem, but as far as splicing those wire together I think you are opening a can of worms it would be easier probably just to reconnect the cut wires.
Old Nov 30, 2001 | 09:34 PM
TCTOOL's Avatar
TCTOOL
Is there something in the column harness that when cut will kill the starter?
Old Dec 1, 2001 | 07:42 AM
jowilker's Avatar
jowilker
TC, With your harness still in place on the truck, it is looking for the connection needed to be able to start the truck in park or netural. I will take a guess here, but you might be able to find the two wires and connect them together to start the truck, the drawback is the truck would start in gear. That seems to be a problem for some of our guys here, but both of my trucks will start with the gear selector in in any position. I have started the truck in gear and now always remember to make sure of where the selector is before turning the key.
Not much help today, huh?
http://www.clubfte.com/users/jowilker/USFlag.gif
John
jowilker email me
[link:www.ford-trucks.com/users/jowilker|My Club FTE Page] Member since 01 01
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NCFTO] North Carolina Ford Truck Owners Group
In the cool still quiet of night, you can hear chevies rusting away.
Old Dec 1, 2001 | 11:41 AM
dinosaurfan's Avatar
dinosaurfan
Outlaw56
Sep 9, 2013 11:14 PM
moconnor603
Aug 25, 2012 09:02 PM
aubeard
Mar 5, 2012 03:14 PM
Diiger
Electrical Systems/Wiring
Jun 6, 2004 08:19 PM
rick
Feb 23, 2000 10:43 PM
