I just flushed my cooling system and swapped my thermostat to a 195 to get me ready for another cold New England winter. 195 should keep me nice and toasty.
I run 180º year round in my FEs, ony one that I have ever install. It doesn't get that cold in central NC.
http://www.clubfte.com/users/jowilker/USFlag.gif
John
jowilker email me
[link:www.ford-trucks.com/users/jowilker|My Club FTE Page] Member since 01 01
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NCFTO] North Carolina Ford Truck Owners Group
In the cool still quiet of night, you can hear chevies rusting away.
[updated:LAST EDITED ON 26-Nov-01 AT 01:28 PM (EST)]>Hi All,
>Just curious to see what temp thermostat everone runs now
>that winter is coming, I have a 170 degree in my truck and
>it seems to never heat up.
I would NEVER run any cooler than a 180* thermostat in a FORD engine.
They were designed to run HOT 195*<
Ford engines do not run economically with cooler than 180*
>Should I go hotter?
Yes, Minimum 180*
What does everone else run?
Summer 180*
Winter 195*
What temp would have come in the truck when it was new?
195*
>351M, C6, Stock.
>Thanks!
>-Brents
78 F-150 429CJ C6 ,Silver w/Explorer Pkge
641/2 Mustang,Pre-World's Fair Car #8092
64 Fairlane S/C waiting for a 390-4spd.
68-Mustang.Sunlit Gold 80,000 miles
>FORD engine.
For most of its life, FE engines were specified with two thermostats, winter 180* and summer 160*. It wasn’t until almost the '70s when they started jacking up the operating temperatures for emissions. Later engine families were designed with higher running temperatures in mind.
True, but they make the most power there, at least according to my timeslips.
I just bought a 180 last night and while looking in the book, I noticed some of the fine print at the bottom. It said to only use a 195 if the cap was at least 7 psi? It didn't make much sense to me. My 195 I have in now runs the temp gauge at 215 so I'm going to swap and see if there's any difference.
205 degrees all year round. One has to remember your engine is a heat pump. The more heat you take away from the engine and throw at the radiator, the less there is to push the pistons up and down. I would never even consider colder than 180*. The coeffiecent of friction between the engine pieces rises as it gets colder and goes down with increasing temps. If I thought the coolant could stand it I would run hotter still, but 205 was the hottest stat I could find. DF
