Transmission Question
Old Dec 26, 2005 | 06:30 PM
manonegine13's Avatar
manonegine13
Hi, I have a 1976 F100 with a 390 and a C6 transmission. I'm having a problem with the tranny. When I first start the truck and put the truck in drive I have to sit there about 5 minutes before my truck will move forward ( reverse is fine ). What do I need to do to fix this? Thanks
Old Dec 26, 2005 | 06:36 PM
ford390gashog's Avatar
ford390gashog
this is the wrong forum for this. we do have a tranny forum and year specific forums.
whats the fluid level?
Old Dec 26, 2005 | 06:38 PM
JD717's Avatar
JD717
it might jsut be the tranny is worn, and may need rebuilding or new fluid. my scout master had the same problem on his 79 F100 with a C4 and I think 302 or 351 motor.
manonegine13
Sorry new to site, how do I get there? thanks
Old Dec 26, 2005 | 06:39 PM
manonegine13
Oh fluid level full, first thing I checked.
Old Dec 26, 2005 | 06:43 PM
ford390gashog
full when idling in park? you need to check it while idling
Old Dec 26, 2005 | 08:24 PM
kennethl6's Avatar
kennethl6
Hard forward clutch seals, overhaul time.
Old Dec 27, 2005 | 02:14 AM
RTM's Avatar
RTM
I agree with kennthl6, rebuild time.
Old Dec 27, 2005 | 08:34 PM
scafes's Avatar
scafes
I have had this problem before and it was the front pump in the tranny going bad. Not able to build enough pressure. It was fine most of the time but once in a while after sitting for a spell it would not shift. Rebuilt it.
