injection driver module
Old Dec 26, 2005 | 04:38 PM
abigjeep's Avatar
abigjeep
The Stealership was kind enough to give me the printout of my latest visit. My Injection Driver module is bad. If I can find where it is I can replace it. Can anyone direct me? Incidentally I have a no fire condition with #5 and #8 and according to the service mgr. I need to replace the valve cover gaskets as the wiring is in the valve cover. Is this the case? I'm new to Diesel. and with my Expy having trouble I need to get one back on the road quick.
Thanks
Old Dec 26, 2005 | 05:17 PM
ltfox's Avatar
ltfox
I would change out the valve cover gaskets and any wiring thats bad before buying a IDM. IDM might not be bad. IDM is on the driverside fender close to the firewall.
Old Dec 26, 2005 | 05:18 PM
mech2161's Avatar
mech2161
The uvc harness is not hard to replace. The injector driver is behind the drivers side inner fender against the fire wall. Remove the inner fender and it is easy to change. I've never seen one go bad and the truck still run. I'd do the wireing first and see how it runs.
Old Dec 28, 2005 | 12:44 PM
lukecline's Avatar
lukecline
if it is the idm look on ebay, usually see some on there and it should be much cheaper than going back to stealership.
Old Dec 28, 2005 | 12:55 PM
wlihntr's Avatar
wlihntr
as said above i would do the valve cover gasket first, here is a place that has pretty good prices on them; http://www.trademotion.com/partlocat...&subcat1=73214
Old Dec 28, 2005 | 02:26 PM
abigjeep's Avatar
abigjeep
We are going to try the valve covers first. I'll let you know what happens.Thanks for the links!
Old Dec 28, 2005 | 03:32 PM
maevans's Avatar
maevans
CHECK THE UVC FIRST!!! Stealership told me that my truck had the code for a bad
idm . $ 1,400.00 later it ended up to be the uvc harness ,I was SOL. My truck would barly run. Good luck.
Old Jan 3, 2006 | 12:55 PM
abigjeep's Avatar
abigjeep
The wiring did the trick! We are back on the road, strong as ever. Thanks for the help
Old Jan 3, 2006 | 01:04 PM
PSNut's Avatar
PSNut
My note pad is being filled out on this one! Great info!
Man this site Rocks!!!
Old Jan 3, 2006 | 06:39 PM
maevans's Avatar
maevans
abigjeep
When you had your truck in the strealership, Did they give you a qoute on repairing the IDM, And do you remember what trouble code they said your truck had.
Glad to hear that it was the harness and not the IDM.
Old Sep 6, 2008 | 12:41 PM
bigrig62's Avatar
bigrig62
what did the wiring harness cost i need to replace mine.
Old Sep 6, 2008 | 05:31 PM
F350-6's Avatar
F350-6
Welcome to FTE bigrig62.
I imagine they cost a little bit more now than they did in 2005 when this thread was started. The cheapest place to get them is usually at an International truck dealer. The IH part number for the harness is 1830844C93
Last I heard they were around $55.
mashenden
62
Jul 29, 2022 12:29 PM
webstrang
Feb 9, 2015 09:07 PM
majestek12
Dec 11, 2013 11:24 AM
TCLyford
Nov 27, 2013 08:06 PM
biblicaltruth
Jul 19, 2013 07:40 PM
