safe engine speed
Old Dec 25, 2005 | 10:37 PM
maxtruck's Avatar
maxtruck
safe engine speed
i am the new owner of my first diesel
the truck is a 2000 drw with a 7.3 and a 6 speed
what is a safe engine speed for long highway trips?
also, is there a difference between gas engine oil and diesel engine oil?
Old Dec 25, 2005 | 11:00 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Welcome to Ford Truck Enthusiasts maxtruck.
You engine is goverened to 3400 RPM. You can pretty much run it anywhere you want to below that.
There is a difference between gas and diesel oil. Look for the diesel ratings on the bottle. You need a 15w-40 weight oil.
Old Dec 25, 2005 | 11:04 PM
maxtruck's Avatar
maxtruck
so i can run at 3000 rpm across the country if i want? and not hurt the engine?
Old Dec 25, 2005 | 11:34 PM
Kwikkordead's Avatar
Kwikkordead
Theoretically you could, but I would never want to push a PSD that hard.
Old Dec 25, 2005 | 11:50 PM
Douglas DC-9's Avatar
Douglas DC-9
Try to stay below 65MPH or 2,000RPMon the highway (as hard as that sometimes is!) You'll see your best fuel economy at or under 2k, rather then 3,300 where you can see the fuel puff out behind you.
DC-9
Old Dec 26, 2005 | 11:08 AM
Black88GT's Avatar
Black88GT
On my long trips, I run it say 2500 rpms for quite some time. (85 mph or so) Is this bad? I was told early on that it was not dangerous, and the truck could do it all day. Thanks.
Old Dec 26, 2005 | 11:13 AM
SpringerPop's Avatar
SpringerPop
The truck CAN do it all day long, day in and day out. They are one mighty-fine "road car", and that's why there are so many of them out in West Texas.
It's just your fuel economy that's gonna' suck any time the RPM's get much above 2000. And it WILL.
Pop
Old Dec 26, 2005 | 01:07 PM
Kwikkordead
With my 4.88' 2500=69 mph. I do that for hundreds of miles at a stretch on while out on vacation.
Old Dec 26, 2005 | 01:37 PM
Hello's Avatar
Hello
Mine can cruise at 90mph about 2700-2800 rpm with the cruise on. I'm just keeping up with the fast guys on the I-5 which is a very fast interstate. When the road starts to wind thru the rolling hills, the cruise will let off going down and floor it going up. All maintaining 90mph.
Also I've nearly redlined mine going up winding roads in 2nd and watching the tach. I was surprised how silky smooth the engine becomes after 3000 rpm. I knew right then this engine is very well balanced and not going to come apart. Was also on the 100hp Predator tune too.
Old Dec 26, 2005 | 02:10 PM
Black88GT's Avatar
Black88GT
Whew, I got scared there for a minute Ive only had it up near the redline once, and that was when the OD was off and I was passing a Chevy :headbang: As far as the fuel cunsumption, What do you all get cruising 2500 or so rpms? Last trip to AZ I got aroung 11.6 This year I will change the oil right before the trip to see how It goes.
Old Dec 26, 2005 | 03:09 PM
Steve_250's Avatar
Steve_250
If you remove the throttle from the back stop you can expect to see around 17 mpg empty.
Here are a few threads talking about economy, good reads.
https://www.ford-trucks.com/forums/s...earchid=252516
Also, the "kwik mod" or 6637 air filter mod may improve your economy and give ya a boost in the seat.
https://www.ford-trucks.com/forums/s...d.php?t=277571
Old Dec 26, 2005 | 03:19 PM
Kwikkordead
There is a rev limiter built into the computer. It will not allow your engine to develope any power beyond that limit. You can stand on the throttle in neutral, the engine will rev to that point and no further.
On my truck it's about 3200-3400 rpm, somewhere in that range. Lot's of people pass me as I limit my speeds to 70 at 2500 rpm when out on the interstate empty or pulling the trailer. I don't hog the left lane either like some people do.
I'll get 13 empty and 9 towing with a fresh oil change before I depart using Mobil 1 Delvac 5-40 and fresh filters all around.
Old Dec 26, 2005 | 05:23 PM
mech2161's Avatar
mech2161
If I can do 4000, 2500 is a walk in the park.
Old Dec 27, 2005 | 04:05 AM
RubberDuck's Avatar
RubberDuck
I dare you to run that monster at 4k for 100 miles.
RubberDuck
Old Dec 28, 2005 | 08:50 PM
maevans's Avatar
maevans
Kwik- What is your GVW of that nice fifth wheel that is following you
My quess is over 10,000lbs
