General Automotive Discussion
Tire size and speedometer reading....
Old Dec 25, 2005 | 02:21 PM
pfogle's Avatar
pfogle
Hey guys, I need some help.. My dad and I got into a debate over tire size VS speedo reading.. It seems that I remember reading somewhere that smaller tires will read faster, and taller slower. Is this right?
Old Dec 25, 2005 | 02:25 PM
76 F-150 390FE's Avatar
76 F-150 390FE
if you have bigger tires than stock you are goin fater than the speedo says, smaller tires than stock you are going slower than the speedo says.
edit: here is a calculator to show that.
http://www.4lo.com/calc/gearspeedo.htm
Old Dec 25, 2005 | 02:26 PM
pfogle's Avatar
pfogle
That's what I thought. My girlfriend was following me the other day and she kept telling me to slow down. I was doin about 70 in a 55....
Old Dec 25, 2005 | 09:57 PM
MustangGT221's Avatar
MustangGT221
Doesn't it depend on the device used to pick up the speed? Whether it's a cable operated speedo in the tranny/TC or in the rear diff?
My truck has 35's on it and if I'm going 70 my speedo says I'm doin' 65 or so cause I havn't recalibrated it. This is just like he said but I wonder if it's different on the cable operated stuff...
Old Dec 25, 2005 | 10:03 PM
Mil1ion's Avatar
Mil1ion
A smaller tire always makes more revolutions in a specifed distance than a larger tire does.
Old Dec 25, 2005 | 11:53 PM
Torque1st's Avatar
Torque1st
Posting Legend
Cable or speed sensor makes no difference. The electronic speed sensors can sometimes be easily calibrated with a tuner etc. Check the chip forum for more info. A cable operated system requires a gear change.
Old Dec 26, 2005 | 09:22 AM
MustangGT221
Our 92-96 trucks can be changed w/o a tuner
What does matter is a gear ratio change - no affect on the axle sensor but does have an affect on the cable version. I was thinking along those lines...
Old Dec 26, 2005 | 11:01 AM
jeffvms's Avatar
jeffvms
I do want to hijack this thread but how does the different tire size play in for gas mileage. I had 235's on my truck and put on 255's. Would i see better or poorer gas mileage on the highway and/or city driving.
Old Dec 26, 2005 | 02:57 PM
76 F-150 390FE
is all you are doing is changing the width?
Old Dec 26, 2005 | 04:20 PM
MustangGT221
Probably wouldn't notice a difference, very minimal at best.
Even with my 35's and more importantly, the right gearing - I still got decent mileage with my truck.
Old Dec 26, 2005 | 06:56 PM
tude's Avatar
tude
the taller the tire the lower you want your gears to be , so that you dont couse stress to the tranny/transfer case and possibly the motor
if you put taller tires on you will be giving it more gas when you are taking off to get them to turn
and smaller tires you will be able to get a faster take off but wont have as much top end
Old Dec 27, 2005 | 11:10 AM
jeffvms's Avatar
jeffvms
Sorry.....my mistake......I changed the height too. I think before it was 235/65R16 and I put on 255/70R16. Tude pretty much answered my question.
Old Dec 27, 2005 | 01:10 PM
Thomasm67's Avatar
Thomasm67
I have 35's on my 76 Hiboy when the speedo says 55 it's running 60 so it's not bad.
Old Dec 27, 2005 | 04:02 PM
pfogle's Avatar
pfogle
I have a '79 LTD, and the tire size on the door sticker is labeled "FR78-14". This roughly translates to 195 75R15.... It has 215 75R15 (makes the tires taller as the height is a ratio of the width) so it's reading 60 when I'm actually doing around 65 to 67. My GF was following me the other day and said she was having to run almost 70 to keep up with me.
Old Dec 27, 2005 | 04:26 PM
preppypyro's Avatar
preppypyro
Stock tires on my 150 when I bought it was 245/75-16, and I changed them to 285/75-16. The speedometer is off, and I am always going faster then the speedomter reads. For mileage, in town it is worse, but on the highway it is a little better.
