1978 - 1996 Big Bronco
quick question maybe dumb
Old Dec 24, 2005 | 05:55 PM
Dj300ford's Avatar
Dj300ford
If the engine is out of time would that make the engine smoke and burn oil?
Old Dec 24, 2005 | 05:56 PM
ctch88's Avatar
ctch88
Have you recently changed the timing?
Old Dec 24, 2005 | 06:09 PM
Dj300ford's Avatar
Dj300ford
no i haven't but it has always burned and smoked and knocks at start up. but runs great
Old Dec 25, 2005 | 10:25 AM
ctch88's Avatar
ctch88
It could be a number of things, we need more info to help though. Edit your signature so we know what truck your talking about (year, size, trans.). If the truck runs well otherwise, it's probably not the timing. Is there a reason why you think it could be the timing? What is it set at now? Does the engine only burn oil on start up, or also as your driving?
Old Dec 25, 2005 | 07:18 PM
aurgathor's Avatar
aurgathor
If it only smokes after you start the engine that's usually leakage through the valve seals. If it smokes all the time (blue smoke), it's usually the rings, or the cylinder is just worn too much. Black smoke usually means too rich mixture.
Old Dec 26, 2005 | 10:56 PM
Dj300ford's Avatar
Dj300ford
Just at start up, or just dont notice it after its running. 1983 302 C6. Pictures finally up in Gallery.
Old Dec 27, 2005 | 04:39 PM
greystreak92's Avatar
greystreak92
If its just at start-up and its the tell-tale "blue" of burning oil, its most likely gonna be valve seals.
Nathan511
Jan 28, 2017 12:36 PM
bgodkin
Ford vs The Competition
Dec 26, 2008 10:23 PM
fordtruckin
Dec 10, 2002 05:26 PM
Gwilkrrs
Nov 6, 2002 08:49 AM
manlikesford
Jan 11, 2001 10:17 AM
