General Diesel Discussion
Cat diesel engine swap
Old Dec 27, 2005 | 07:23 PM
  #31
perky's Avatar
perky
The 3156 is in the backholes and in some of the rubbertire loaders same has the 6.0 Perkins I hhave in my 75 f250 mine stock was 190hp at 2600rpm 575lb tq at 1600rpm lighter wt.than the 5.9.
Old Dec 27, 2005 | 08:17 PM
  #32
HT32BSX115's Avatar
HT32BSX115
Is that the 6-354?
Old Dec 28, 2005 | 07:25 PM
  #33
perky's Avatar
perky
No it is not, differant block much guiter and smoother.lookin my galleryat my the block looks like that .
Dale
Old Dec 29, 2005 | 10:07 PM
  #34
HT32BSX115's Avatar
HT32BSX115
That truck is very cool!
Have you ever had it on a chassis dyno? What sort of rear wheel HP do you think you're getting?
Also what is the model number of the engine? (this is the one you were talking about?)
What will bolt up to the engine? (trans)
Dale
Old Dec 30, 2005 | 08:40 PM
  #35
perky's Avatar
perky
You can get adaptors from Perkins for all typs of tranys.My motor is a 1000 series YE motor.I have had it on 2 chassie dynos not a load dyno.I can,t get load the motor hard enough on a syntrifical dyno.the guy told me that after I ran it.My buddy has a 5.9 Cummins 485hp 990tq booth of us grossing at 23.000lb I can pass him on a steap grade hand get better fuel milage.booth have 3.54 rear end.
Dale
Old Dec 30, 2005 | 10:13 PM
  #36
Kwikkordead's Avatar
Kwikkordead
Dale
What did you do to the Perkins to outpull a hopped up Cummins like that?
Old Dec 30, 2005 | 10:16 PM
  #37
Kwikkordead
Never mind, I found your gallery. Very impressive.
Old Dec 31, 2005 | 02:12 AM
  #38
HT32BSX115's Avatar
HT32BSX115
Sounds like you really scored on that engine. Where would one find one for a good price?
It's possible to buy a used Cummins 6bt from just about any wrecking yard for around $2000. It appears that the Perkins 1000 series is new enough that it might be hard to find one used and they probably cost a small fortune new or used.
I'd love to put one in my F-600 in front of an OD auto trans.
Dale
Old Dec 31, 2005 | 10:07 AM
  #39
perky's Avatar
perky
They have been around since the early 90s mine I bouhgt new in 96 .I found one in Indiana the sister to mine for 2700.00 they do have dry sleaves for rebuilding.can find them cheaper with the round pump on them.The 5"in stroke and the 3.93 bore is what gives so much tq.Idid alot changes from when I ran my buddy had stock Injectors and small adjustments to the injection pump stock timing.Now I have 330hp marine inj.Pump max out now.I have alot bigger turbo setup the other setup was way to small tomuch back pressure.Working on making the walnut dash for all new gauges& heater controls.My wife keeps asking me if I,m ever going to stop playing with that truck and leave it alone and just drive it.I just smile and walk away fast.
Dale
Old Dec 31, 2005 | 10:10 AM
  #40
perky's Avatar
perky
Just do a search on perkins diesel 1006series alot out there.
Dale
Old Jan 7, 2006 | 11:17 PM
  #41
Cat man's Avatar
Cat man
I apologize, it's a 3116 Cat not a 3156. GM's Top kick medium duty truck can have a 3116 Cat in it, a company I used to work for had a truck like this and it was terribly underpowered while towing a 580L Case backhoe. But in a fullsize truck I figure it would be especially the turbocharged 285hp one, what do you guys think, what about ease of fitability in to a '73 Ford F-250 4x4? What is the weight of the Cat compared to a Cummins and would i still have to update to Rockwell axles and a Rockwell transfer case to deal with the Cat or is the power output low enough to run 1 ton drivetrain? Any other info would be much much appreciated thanks.
Old Jan 8, 2006 | 01:29 AM
  #42
85e150's Avatar
85e150
Originally Posted by Cat man
i have a chance to buy a '53 GMC military 6x6 and the old 6 cylinder is hard to find parts for and so is the transmission would a 3208 fit better under the hood of this machine with a industrial manual transmission? just curious on your opinion
I don't know if this is still in the plans, but my old man used one of these trucks for years. The drive train is not up to this kind of power. He used to break things with the six. (a 302 Six, 4"x4", 2bbl Mercury carb, 4 speed Hydramatic, 2 speed divider box, full time 6 wheel drive by means of some kind of overrunning clutch, so if you got slippage in the rear, the fronts kicked in...)
Anyway, on of the things he discovered was the ring and pinion set was the same parts as used in Chev/GMC one ton's in the '70s. Not very heavy duty.
These were rated to haul 2 1/2 tons for the military. He had about 18000lbs on it daily, and broke one of the axle housings at one time.
Old Jan 8, 2006 | 04:59 PM
  #43
Cat man's Avatar
Cat man
I could have picked the GMC up for $1200 and the only thing was a drain plug in the transmission fell out and the fluid all drained out driving up the hwy. and he had it towed home, he just wanted to get the money back for the tow bill.(It was a long way from home). I also had a chance to get a late 70's Kaiser military 6x6 that had a diesel, if it dosen't already have a 3208 would this be a truck to put the Cat in? Your right the GMC didn't have rockwell axles but the Kaiser does, is the drivetrain in the Kaiser a bit tougher then the GMC? What do you guys think would be a better project, a '73 Ford F-250 with a Cat 6 cyl. or a Military 6x6 with a 3208 Cat put in it? just curious.
Old Jan 8, 2006 | 06:53 PM
  #44
fellro86's Avatar
fellro86
While the 6x6 would be cool, the military spec parts can get pricey in a hurry...
Brad Johnson
Feb 18, 2006 11:39 AM
endabcs
16
Nov 5, 2005 04:35 PM
