Ambient air sensor
Old Dec 23, 2005 | 05:07 PM
dadj's Avatar
dadj
Smile Ambient air sensor
The outdoor air temperature sensor on my 2000 Expedition started acting up recently. It would read accurately when cold but would start reading a higher temp as the engine heated up. The electronic temperature control will not work properly without this input. The dealer said it was a faulty Ambient air temperature sensor part number F3VY12A647A and cost $101.40 plus installation. A few hours on the internet came up with A NAPA part number TS4005 and a Standard Parts Corp. part number TX12 both can be found at your local parts store for under $20.00 and on line for around $13.00.
The sensor is mounted on the front of the radiator frame under the plastic shroud just to the right of the hood latch assembly. It's a simlpe plug in install.
Old Dec 23, 2005 | 06:36 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome dadj, to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Dec 24, 2005 | 11:36 AM
snoVVman's Avatar
snoVVman
Good tip. Thanks for sharing the information. What were the symptoms with your electronic temperature control, aside from incorrect reading?
dbeckwit
Mar 1, 2014 07:49 AM
mu2bdriver
19
Feb 17, 2014 03:00 PM
Firefighterdan
Aug 22, 2012 12:00 AM
JeffG5
Jun 28, 2012 09:15 PM
yaroslow
Escape & Escape Hybrid
Jan 30, 2009 04:37 PM
