Trouble Bleeding Explorer Brakes
Old Dec 22, 2005 | 05:07 PM
Repsher's Avatar
Repsher
I had to replace a hose on my 1994 4x2 ford explorer today because of a leak. I'm now trying to bleed the brakes and can't get the bleeder screw to budge. 3/8" wench is to small, 7/16" is to big (I striped part of the hex with this) and even tried 10mm which was too small. Already tried prenatrating lube to help but the dang thing won't move. What should I do, I was thinking of getting a 13/32" wrench tomorrow and giving that a try but besides that I don't know what to do. Please help.
Mike
Old Dec 22, 2005 | 05:14 PM
1081's Avatar
1081
Front or back and drum or disc?
Old Dec 22, 2005 | 05:16 PM
Repsher's Avatar
Repsher
I'm working on the front right disk brake right now (the one that's giving me trouble). Have drums on the back, think all the bleeder screws should be the same size right?
Old Dec 22, 2005 | 05:26 PM
1081's Avatar
1081
Let the penetrating lube sit on there overnight and try the wrench thing tomorrow. Occassionally I have been able to get a small socket on it (a little smaller than the valve since it is stripped), tap it down and get them loose. This puts pressure on all sides and not two or three sides. I don't know if it is possible to drill and replace that valve, but I thing the worst case scenario would be replacing the caliper. However, someone els here may have a better idea.
Old Dec 22, 2005 | 05:29 PM
marragtop's Avatar
marragtop
Use a pair of needle nose vice grips. Don't force it, or you will shear it off. Also, you can bleed the hose and the line going to the hose by bleeding it at the bolt that holds the hose to the caliper.
Old Dec 22, 2005 | 07:10 PM
yield2s's Avatar
yield2s
do as mentioned above and from now on only use a six point socket or box end for any brake fitting.
Those bleeder screws are cheap so just get some new ones.
Old Dec 22, 2005 | 08:55 PM
dogman's Avatar
dogman
I think it's a 11mm.
Old Dec 24, 2005 | 12:30 PM
Repsher's Avatar
Repsher
Thanks for the help, I tried but just threw in the towel an took it to the shop, 5 buck for the parts and 60 bucks to bleed the brakes, kinda a ripoff but they got the job done quick
Old Dec 24, 2005 | 08:34 PM
1081's Avatar
1081
sometimes the money is worth it.
good to doo
Oct 15, 2022 03:19 PM
Don Vito
16
Oct 31, 2016 10:41 AM
jonmammenga
19
Aug 17, 2015 05:05 PM
Iowa-Rob
1983 - 2012 Ranger & B-Series
Jul 27, 2015 11:55 PM
John7894
Dec 28, 2002 10:53 PM
