Offroad & 4x4
Another NP205 Question..
Old Dec 22, 2005 | 06:59 PM
monsterbaby's Avatar
monsterbaby
Ok here is a question, Ivan and I were just discussing this. Since as far as either of us can remember the NP203s all used short adaptors, and the np205 will bolt to that adaptor. and since I know all of the short adaptors I have are alum (only one I have that I haven't bothered to check is the one long one that is still bolted to the transmission, and tcase) I am wondering if instead of having 2 versions of the short adaptor if Ford didn't use the same adaptor for both cases, and make an Iron adaptor for the longer one. So the question is can anyone verify that you have a short adaptor that is made of iron instead of alum? easy to check if you have the short one in your truck go put a magnet on it and see if it sticks. I am just curious about this since all of mine are made of alum atleast in the short version
Old Dec 22, 2005 | 07:02 PM
brokebronco's Avatar
brokebronco
I dunno, maybe I have a semi-rare adapter. It is a heavy cast piece with the shifter notch already cut out.
Chris
Old Dec 22, 2005 | 07:55 PM
fishmanndotcom's Avatar
fishmanndotcom
both my adapters, short and long, are steel/iron. i know for a fact b/c first they are heavy as hell and second my electromagnet picked'em up
-cutts-
Old Dec 22, 2005 | 09:07 PM
proeliator's Avatar
proeliator
Originally Posted by The SnoMan
while it is in a "O" state...
Is that anything like an "O" face
Old Dec 22, 2005 | 09:38 PM
ivanribic's Avatar
ivanribic
Rob, just tell people you used aluminum to cut down on weight so the truck was faster. I'm gonna go out in the garage here in a few minutes and see if I can dig out my short adapter. I'll let you know what I find out.
Old Dec 23, 2005 | 07:23 PM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
dang i never realized the 205 was 170lbs cutts, is that with the adaptor?
Old Dec 23, 2005 | 10:10 PM
brokebronco
Ivan, is the short adapter from the short bus you used to ride on?
Chris
Old Dec 24, 2005 | 12:07 AM
fishmanndotcom
yes with adapter but that thing isn't but 10 lbs or so
-cutts-
Old Feb 22, 2006 | 06:38 PM
SwOkcOffRoader's Avatar
SwOkcOffRoader
ok, i got a NP 205 the other day...while i was under my truck it hit me that the 203 sits furthur back because of the range box, i know im gonna have to do something about driveshafts, im wondering if im going to be able to relocate the Tcase support bracket, or will i have to get the bracket off the donor truck....hopefully they didnt cut it up like they did the front driveshaft...
Old Feb 27, 2006 | 03:41 PM
Jmudder79's Avatar
Jmudder79
When i first bought my 79 250 it had a c-6 and 203 in it. I fried the c-6 nand I had another c-6 with a 205 out of a bronco i had. It all bolted right up without any adapter plates needed. I did have to move the the t-case mount up, get a shorter front shaft and a longer back shaft. You may be able to get away with your original shafts though, thats just how I did it. I also swapped out the crappy full time hubs for a set of manual mile markers.
Old Feb 27, 2006 | 07:56 PM
SwOkcOffRoader
ill probably leave the full time hubs since i have no use for total 2wd....i figure that if i leave the full time hubs in that will be two less parts to break...
Old Feb 27, 2006 | 08:22 PM
KubotaOrange76
drive slugs/drive flanges are wher eits at
Old Feb 28, 2006 | 06:30 PM
  #28
bremen242's Avatar
bremen242
as long as it isn't your DD and they must be in the "O" state.
Old Mar 1, 2006 | 02:14 AM
  #29
460's Avatar
460
I think the adapter on my 203 was the short version, and it was iron because it began to rust after sitting outside for a while. It was missing the notch to clear the shifter rail for a 205. http://i44.photobucket.com/albums/f2...7-05-05005.jpg
Old Mar 2, 2006 | 04:58 PM
  #30
brian0357's Avatar
brian0357
of course they came with 4 speeds! Name:  transagain.jpg
Size:  67.0 KB It took 3 guys and an engine hoist to get it in plus about 2-3 hours. it was a real bitch but I pulled the hoist inside the cab and dropped the arm and a strap through the tranny pan. I just lifted the trans and transfer case in and it took alot of heaving and wiggling to get it in.
