surge
Old Dec 21, 2005 | 07:53 PM
Don Brill's Avatar
Don Brill
surge
I have a 93 Explorer with a 4.0. It seems to have a surge at medium throtle and medium load. The air cleaner is good and I put 2 bottles of injection cleaner thru it with no change. Any ideas?
Old Dec 21, 2005 | 09:26 PM
JerrySimm's Avatar
JerrySimm
Have you pulled the codes to see if any are present or were previously stored. My first suspicions would be the MAF or the TPS.
Old Dec 22, 2005 | 01:08 AM
Jharger's Avatar
Jharger
General maintenance - plugs, wires, PCV valve, vacuum leaks, O2 sensors, clean MAF sensor...You don't give much info here. How many miles, what kind of maintenance history, what's a "medium load"?
Old Dec 23, 2005 | 03:31 PM
Don Brill's Avatar
Don Brill
Ok lets make this a little clearer. When I climb a hill but I'm taking it easy (not getting into the gas to hard) the engine surges slightly as if I were stepping on the throtle and letting off slightly. It's not a big surge but it's there and tells me something isn't quite right
Thanks for your input
Old Dec 23, 2005 | 03:35 PM
marragtop's Avatar
marragtop
As previously suggested, you should pull the codes. Although the CEL is not on, it can still throw and store a code.
Old Dec 23, 2005 | 04:12 PM
Jharger's Avatar
Jharger
Don - really know what you've done so far and what results each action have provided. How many miles is a big quetion. A 1993 like mineis, I assume the miles are up there. Have you ever cleaned the MAF sensor? have you evey chnaged the plug wires. i went about 150K mile before I ever changed my wires - I had symptoms like you are describing but never got a PCM code for it. Chack out this web site for a lot un unkonow truths about early explorers. http://draco.acs.uci.edu/explorer/ And go to this one about general Ford Fuel Injection - this is a great web site! http://www.fordfuelinjection.com/
rpss4844
Nov 23, 2023 08:00 PM
Don Brill
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Dec 22, 2005 11:01 PM
PsRumors
General Automotive Discussion
15
Jan 22, 2005 04:18 PM
kyuss
Dec 14, 2004 09:52 PM
