two copper plugs behind horn button?
Old Feb 6, 2006 | 06:49 PM
mclaughlin31's Avatar
mclaughlin31
Hey there,
Was curious as to the purpose of these two copper plugs behind the horn button. I am currently not running a horn that uses the stock horn button, but after approx. 1000 miles(with Grant wheel) I can hear something making a scraping sound behind the horn button(inside the steering wheel area) whenever I turn the wheel. I changed to a Grant steering wheel and wasn't sure if I just didn't goof something up. I put a lttle dielectric grease on the copper plug end and it stop making the noise for a little while.
Any insight would be appreciated.
James
Old Feb 6, 2006 | 07:56 PM
mhg's Avatar
mhg
these are brushes for the horn
make contact on two stips of copper on the bottom
of the steering wheel
Old Feb 6, 2006 | 08:00 PM
garypettengill's Avatar
garypettengill
If you're working on your '77 and it's the origional steering column then you have a cruise column and one is for your horn and the other is for the cruise control.
79FordBlake
37
Nov 11, 2013 08:35 PM
F350moneypit
19
Feb 4, 2013 01:46 AM
laynrubber
May 4, 2007 10:20 PM
mcne
Electrical Systems/Wiring
Oct 13, 2005 09:37 PM
