Replace headlight switch
Old Dec 21, 2005 | 11:21 AM
seneca's Avatar
seneca
Question Replace headlight switch
I want to replace the headlight switch and any bad bulbs in the instrument panel in my 78 f-150 4x4.
Does anyone have any suggestions?
My truck's name is KNARLY.
Old Dec 21, 2005 | 11:25 AM
bulrydr_1's Avatar
bulrydr_1
If you do a search in this forum, you find PLENTY of threads showing you how to do this.
If you can't find what you are looking for, then post back with specific questions, and they'll get answered....
Mike
Old Dec 21, 2005 | 11:30 AM
seneca's Avatar
seneca
Thanks MIke -I'll do the search.
Seneca
Old Dec 21, 2005 | 01:44 PM
Mil1ion's Avatar
Mil1ion
What exactly is your question ?
How about being specific ?
Old Dec 22, 2005 | 04:11 PM
T18skyguy's Avatar
T18skyguy
The important thing to remember about the headlight switch is there is a button on top of the switch. You need to depress and hold this button then pull the switch and rod straight out of the assembly. Everything is easy after that.
Old Dec 22, 2005 | 04:24 PM
derherr65's Avatar
derherr65
Be prepared to buy a new instument panel. The white backing plate can get really fragile. That was the reason my lights went out. I found a whole cluster, all guages, in good shape at a junkyard for $25.
Old Dec 25, 2005 | 09:44 AM
seneca's Avatar
seneca
Replace Headlight switch
A great idea.--Although the cluster in my truck is in good shape I will get one
from the junk yard as a backup. I'm sure they are getting scarce.
Thanks
My truck's name is Knarly.
Old Dec 25, 2005 | 03:22 PM
Torque1st's Avatar
Torque1st
Posting Legend
Actually many years of back panels interchange even among the vans based on connector size etc. Most of the time it is better to leave the parts in the junkyard until someone needs it. Otherwise it sits around in your shop and collects dust until it gets broken or you forget where it is when you need it.
krmoore77
1997 - 2003 F150
Dec 27, 2020 08:24 PM
Green Giant
Apr 9, 2012 02:59 PM
apbtpetey
Electrical Systems/Wiring
Dec 1, 2008 02:18 PM
newkyford
Dec 15, 2006 11:45 AM
gary678
Aug 30, 2006 08:30 PM
