High Idle
Old Dec 20, 2005 | 12:08 PM
chazb86's Avatar
chazb86
Red face High Idle
Hi everyone I have a 86 F150 302efi AOD tranny, my problem is after the engine warms up when I put it in drive it idles high drives fine but at a stop you still could here the engine idle high. And when I put it into reverse it will jerk once in that gear, I would have to put it in netrual first let the engine idle down then put it in gear. And last after driving several mile or so it shut off in park I would have to keep my foot on the gas for it not too. So for what I've done thinking vaccum I sprayed the entire engine with soap and water looking any air leaks (twice) none found. Could someone please give me some cheap ideas before it may have to go to a shop. I also have a small code reader the last time I pulled a code it read clear.
Old Dec 20, 2005 | 01:55 PM
mnmzimmer5's Avatar
mnmzimmer5
I would try checking the timing, if not check your fuses (maybe eec fuse blown)
Old Dec 20, 2005 | 05:11 PM
redwood's Avatar
redwood
Fuel filter? Idling high when cold, then shutting off when warm...... Just a shot in the dark, but I'd change the fuel filter......
Old Dec 21, 2005 | 07:29 AM
chazb86's Avatar
chazb86
Red face High Idle
Thanks guys for the info I will look at these and let you know if they help.
Old Jan 4, 2006 | 01:13 PM
chazb86's Avatar
chazb86
Red face High Idle
Hi guys, I have may have fix the problem. Premit? I don't know. What I did was pulled the battery cables ( both to clean) to shuting down the system pulled the wire off the EGR sensor after a few seconds I reconnected the cables turned the switch on and off twice, connected my code reader the only code came was the a problem with the EGR, cleared the code reader reconnected the EGR and ran another code the reading was all clear. Started the truck idle to operating temp. drove around after 15 min I put it in park the high idle was gone the same in reverse and it didn't shut off. Again I thank thoughs who responded.
Old Jan 4, 2006 | 07:36 PM
dlbelton's Avatar
dlbelton
Sometimes you have to disconnect the battery for a little while to reset the little computerman... The system tries to compensate for the errors it has stored, sometimes even if the problem is already gone.
Merculous
6.4L Power Stroke Diesel
17
Nov 1, 2013 10:02 AM
vboxingguy
Apr 5, 2012 09:51 AM
magneto259
1983 - 2012 Ranger & B-Series
15
Jan 14, 2012 01:56 PM
sbauld
Oct 15, 2003 07:48 PM
blueman
Mar 27, 2002 06:24 PM
