temp range for 10w30
Old Dec 19, 2005 | 06:42 PM
tjbeggs's Avatar
tjbeggs
i am planning on switching to 10w30 rotella instead of 15w40 for easier starting. but i just want to make sure the temp range recommended is going to be where i am at all winter. and since the previous owner lost the owner manual and diesel suppliment and mitchell on demand only says 15w40 i figured you guys could help me out.
thanks
tim
Old Dec 19, 2005 | 08:50 PM
chapguy's Avatar
chapguy
Just be sure that you change to a diesel rated oil. I've never seen a 10-30 that was for diesels.
Old Dec 20, 2005 | 04:29 AM
1997F-350's Avatar
1997F-350
i am pretty sure delo makes a 0-30 diesel oil...
Old Dec 20, 2005 | 06:16 AM
tjbeggs's Avatar
tjbeggs
shell makes rotella t 10w30. same as 15w40 rotella but 10w30.
so anybody have temp range from their owners manual? what are the outside temperatures that recommend use of 10w30?
Old Dec 20, 2005 | 10:15 AM
73cntry's Avatar
73cntry
The temp would be 20 Deg and up for 15W-40(Preferred). 10W-30 20 Deg to -10 BELOW O(Preferred) Also has from 50 Deg to -20 below %W-30 can be used. Those are in Deg F and found in the 7.3LDIT Owners Supplement Guide
Hope that helps Tjbeggs
Old Dec 20, 2005 | 10:52 AM
tjbeggs's Avatar
tjbeggs
Thanks 73cnrty That Exactly What I Needed To Know!
Old Dec 20, 2005 | 11:51 AM
jimkidd's Avatar
jimkidd
I'm using the synthetic Rotella T. 5W40?
Old Dec 20, 2005 | 03:39 PM
73cntry's Avatar
73cntry
Smile
your welcome tjbeggs
Old Dec 20, 2005 | 03:44 PM
ford390gashog's Avatar
ford390gashog
diesel oil is made in all weights rotella makes
10w,20w,30w,40w,5w30,0w30,10w30,5w40,10w40,15w40
they make a oil for any temp.
anthonym92
21
Sep 12, 2015 03:42 PM
afinepoint
25
Jul 27, 2014 09:39 PM
Mr James
Nov 17, 2013 05:35 PM
TallPaul
Oil & Lubrication
Sep 22, 2003 12:31 PM
MarcusBear
Oil & Lubrication
Jun 19, 2003 09:26 PM
