1978 - 1996 Big Bronco
Glass top
Old Dec 19, 2005 | 06:10 PM
1970Custom's Avatar
1970Custom
Glass top
did Ford ever make changes to the fiberglass tops on the full-size broncos?
Old Dec 19, 2005 | 10:36 PM
jdmorg's Avatar
jdmorg
I don't think so, but some guys in here have. I can't remember who exactly, but if you search around you'll find it. One of them will probably chime in too.
Seat belts and third lights I guess is all?
Old Dec 19, 2005 | 11:18 PM
1970Custom's Avatar
1970Custom
I'm talking more in the structure, like swapping one from a 79 to a 90s.
Old Dec 20, 2005 | 03:04 PM
Towmanjbo's Avatar
Towmanjbo
I was told by some one at one time that they were all the same from 78-96 except for the third brake light and seatbelts. I'm not sure that person was relable but he did have six broncos of various years in his yard at the time. If that was true I would think that the ones with the sholder stap seatbelts would be stronger.
Old Dec 20, 2005 | 05:36 PM
greystreak92's Avatar
greystreak92
78 and 79 are the same, the change came in 1980 but they remained virtually identical from 80 through the end of production in 1996. 1992 saw a minor change when the high-mount stop lamp was incorprated into the exterior cargo lamp above the rear window and the anchors for the shoulder harness rear seat belts were added above the middle of the side windows. 1978-79 tops are interchangable and 1980-96 tops will swap with no trouble. 78-79 tops will not swap to 80 or later.
Whitey Ford
Jan 14, 2015 01:38 PM
aajn
1997 - 2003 F150
Mar 28, 2006 09:35 AM
deepbass
Aug 6, 2005 01:44 PM
Jerry Gougeon
General Automotive Discussion
Dec 16, 2004 08:41 PM
Pioneer Ford
Jul 19, 2002 02:51 PM
