Ranger rough Idle and Stalling
Old Jan 6, 2004 | 05:54 PM
sporty boy's Avatar
sporty boy
Hey guys and gals I have a 1994 Ford Ranger 2 wheel drive with a 2.3 It seems to be getting worst as time goes on. It idels rough and sometime it will stall It does get a little better the longer you drive it. The volt meter seems to drop when it starts to stall then it comes back up. Any help you could give woulb be thankful.
Old Jan 6, 2004 | 07:58 PM
87 XLT's Avatar
87 XLT
Always start with the simple stuff. In this case try cleaning the idle air control valve.
Old Jan 6, 2004 | 08:24 PM
Ken00's Avatar
Ken00
Welcome to FTE!!
The reason the meter drops is because the engine speed drops and the chage rate drops. I would start by checking for codes, see pulling the eec-iv codes in the tech info post, nad testing the fuel pressure.
Old Jan 6, 2004 | 08:52 PM
hreed's Avatar
hreed
Also check for loose or broken vacuum lines. If you have a guage, check the vacuum.
Old Jan 7, 2004 | 05:54 PM
sporty boy's Avatar
sporty boy
Thanks for the infro I will try to pull the codes and also clean the idel air control. I have already visualy checked for vacum leaks maybe I can get a gauge and go that route.
Azfordracing
Mar 21, 2021 09:13 AM
Delonge2002
Jun 8, 2016 01:00 PM
dluchsin
Apr 19, 2014 09:50 PM
320kmiles
Jan 19, 2014 09:35 PM
Viper2
Mar 24, 2005 10:10 AM
