painting dash
Old Dec 22, 2001 | 01:13 PM
otto's Avatar
otto
painting dash
Old Dec 27, 2001 | 06:23 PM
CRJ900's Avatar
CRJ900
painting dash
I sanded and scuffed my dash... didnt take it out... anyway. i decided to paint the glove box cover first, i took it off and it was already sanded. It was nice and smooth. When i went to paint it some parts wouldnt get covered up, they were like little marks.. many of them, the paint i got is for the outside of the truck, do you think this might have anything to do with it. I am going to go to a hardware store and get a regurlar spray paint closest to the color of the outside of my truck. Soooooo why would it be doing this?
Old Dec 27, 2001 | 06:29 PM
Mil1ion's Avatar
Mil1ion
painting dash
After you sand the item with 220 Grit wet paper.
Did you wipe the item with lacquer thinner to remove finger oil and other bad stuff ?
It has to be perfectly clean you know,otherwise you will end up with fisheye or other imperfections.
Prime coat the piece with *Sandable primer* > sand >then wipe with a tack cloth> Paint in light even coats <
Did you use spray Lacquer Paint?
You should !
Dennis
78 F-150 429CJ C6 ,Silver w/Explorer Pkge
641/2 Mustang,Pre-World's Fair Car #8092
64 Fairlane S/C waiting for a 390-4spd.
68-Mustang.Sunlit Gold 80,000 miles
Old Dec 27, 2001 | 08:56 PM
CRJ900's Avatar
CRJ900
painting dash
i am stupid I didnt even use a primer. But good thing is that all i painted was the glovebox. Im gunna sand and paint every thing tommorow. I am going to prime it first, hopefully it'll look better. Also, what type of paint did u say i should use... and also what type of sandpaper should i use on it, i used 400 grit and the sandpaper would just get too smooth so it wouldnt do anything after a few scapes.
Old Dec 27, 2001 | 09:05 PM
Mil1ion's Avatar
Mil1ion
painting dash
Start with 220 then graduate to 400 >then 800.
Wipe with lacquer thinner to remove finger oil.
prime with a sandable / lacquer friendly primer.
Sand lightly >Then, wipe with Tack cloth > paint in a sweeping motion
light coats,let the paint get tacky between coats.
Then use Lacquer available at any GOOD auto parts store
After you have finished painting,let it cure for a while before doing any work around the painted surface.
In 3-4 months it will be as hard as a rock & Shiny.
TOO BAD the U.S.of A don't have a Canadian Tire stores.
You guys and girls would go nuts and want to sleep there if you did.
Dennis
Old Dec 28, 2001 | 05:51 PM
CRJ900's Avatar
CRJ900
painting dash
I painted it. I used an Auto primer.. Put a few coats of that on it. Then i used a color called wimbelton white.. (if any of you heard of that) It looks very good, but i was wondering if it is going to get harder over the next few days or so. Its dry but if i take my fingernail or screwdriver and tap it it will smoosh the paint down and show the primer... it was doing this about 6 or 8 hours after i painted it... so i was just wondering how long its going to take to fully harden. thanks
Old Dec 28, 2001 | 05:57 PM
Mil1ion's Avatar
Mil1ion
painting dash
[updated:LAST EDITED ON 28-Dec-01 AT 06:57&nbsp;PM (EST)]
Wimbledon White was used on Mustangs and other Fords.
It's a very Nice white!
I told you about the curing!
Lay it in front of a heat vent in your house for a few days and see what happens.It will only get harder.
If you used Enamel,it will take longer than Lacquer to cure.
*DON'T put is near a light bulb or that kind of heat.
Dennis
Old Dec 28, 2001 | 06:16 PM
CRJ900's Avatar
CRJ900
painting dash
im gunna leave a heater in my truck tonight
phoneman91
Paint & Bodywork
Apr 28, 2016 07:59 AM
Mountain Monkey
13
Mar 24, 2012 12:12 AM
bryanknie
19
Jan 19, 2012 03:25 PM
phoneman91
Jul 21, 2009 06:08 PM
77fordguy
Paint & Bodywork
Jul 15, 2006 06:56 PM
