rod bearing replacement
Old Dec 17, 2005 | 06:38 PM
wrenchturner's Avatar
wrenchturner
can it be done in truck, i have a 93 f150 2wd auto 300 I6?
Old Dec 22, 2005 | 12:15 AM
nighthawk285's Avatar
nighthawk285
yeah, you can do this in-frame, but it might be easier to take the engine out. To do it in-frame, you have to jack up the truck on the framerails (not the suspension/axles) so that the engine will come up more above the crossmember for the axle. Once you get it high enough, you can take the pan off and start fanangaling a ratchet in there to take off the rod caps, just be really careful when spinning in new ones that you get them in straight, as with the angle you'll be at it might be difficult, and use plenty of pre-lube for them. That might also be a good time to polish the crank while you have the pan and bearings off. Good luck.
Old Dec 22, 2005 | 08:13 AM
Thomasm67's Avatar
Thomasm67
First how many miles does the engine have if your gonna replace the rod bearing you might as well just pull the engine out and tear it down and just do a complete overhaul and first of all you can't polish the crank while it's in the engine. So you have new bearing on the crank new cam bearings new rings have the valves reseated. All of those things are not costly. Trying to do it with the engine still in the truck will be costly after your done and everything is put back together and you spin a new bearing or your rod caps fall off cause you couldn't get them torqued down properly.
Old Jan 2, 2006 | 07:33 PM
canadian 94 ford's Avatar
canadian 94 ford
the first question is why you want to replace the bearings. if it is because of low oil pressure check it with a manual gage. my 4.9 has 364,587klms on it and i would not even think of installing new ones
russellkr
Nov 2, 2002 11:18 AM
beartracks
Oct 18, 2002 02:20 PM
dale i
Sep 22, 2002 09:37 AM
rogwelch
Feb 12, 2000 11:29 PM
Jan 28, 2000 06:08 PM
