performing an oil change....
Old Dec 17, 2005 | 04:28 PM
dannyo's Avatar
dannyo
and was curious as to what type of oil to use? synthetic or regular old oil? what weight? i live in tx so i'm not worried about cold weather. i think ford recommends 15w40?
danny
'01 4x4 Ex 7.3L
Old Dec 17, 2005 | 04:46 PM
NewXer's Avatar
NewXer
You'll find many discussion threads in this forum about oil. Make sure you use the Diesel formulation of the oil you choose (CH or CI).
I use the Shell Rotella T. Its fairly priced, has a very good reputation, and stays pretty clean for my 3500-5000 mile change intervals. I'd previously used Mobil 1 on all my vehicles (still do no my little rice-burner), but $75 an oil change just for the oil is a little too steep for me without a strong return on the investment. I am planning on picking up a by-pass filter to help keep the oil in the engine cleaner.
Good luck,
Larry
Old Dec 17, 2005 | 10:22 PM
dannyo's Avatar
dannyo
what type of filter?
Old Dec 17, 2005 | 11:41 PM
dannyo's Avatar
dannyo
also, is there some anti foaming agent i must use?
Old Dec 18, 2005 | 12:02 AM
Mwachel's Avatar
Mwachel
As for the type of filter. Go to your local auto parts store and open up a few of the filters that will fit your truck. Look at the patent number on all of them. 90% of them are the EXACT same filter. Motorcraft and STP are the same and I paid $5 less for the STP! Don't take anyone's word for it and go look for yourself. I did.
If you live where it gets really cold or you tow a lot then synthetic may be worth it for you. I use Rotella T here in Vegas but I may switch to a synthetic during the winter since I spend a fair amount of time in Utah.
Good luck.
Old Dec 20, 2005 | 09:28 PM
NewXer's Avatar
NewXer
Thats a good point about the synthetic in cold weather... the 15w40 is gets pretty thick. The diesel formulation oils takes care of soot control & foaming to my knowledge.
roy123
Aug 18, 2013 06:11 PM
Vinford
15
Jul 19, 2012 01:08 AM
mongoo
2009 - 2014 F150
18
Aug 8, 2010 11:21 AM
martin123456789
Jul 26, 2010 06:54 PM
Saxon
Sep 2, 2004 10:03 AM
