oil leak
Typicaly a rear main seal will leak into the bellhousing where a pan gasket leak is outside the bell housing.
Your oil leak could also be a leaking rear intake manifold gasket or valve cover gasket with the oil running down the back of the engine.
Best to clean everything thoroughly and do a daily inspection to see where the oil is coming from. Some shops have a dye they can put into the oil to help locate the leak,
Roger Carter
Roger Carter
ksubigbuck
05-03-2007 04:41 AM
