oil changing technique 4X4
Old Dec 17, 2005 | 11:49 AM
tastyklair's Avatar
tastyklair
Just wondering is any of you have a simple technique to keep the oil from running all over the front differential when you change the filter?
Old Dec 17, 2005 | 12:51 PM
53fatfndr's Avatar
53fatfndr
I usually just fold up a piece of cardboard and aim it towards the bucket.
Old Dec 19, 2005 | 01:23 PM
seneca's Avatar
seneca
After I loosen the filter I hold a wad of paper towles under the filter and quickly unscrew the filter.Then I use the towels to wipe away any excess with my left hand while holding the filter upright in my right hand. Then I very carefully remove the filter so as not to spill the oil.
My truck's name is KNARLY.
Old Dec 20, 2005 | 01:00 AM
roushracing617's Avatar
roushracing617
4" of lift took care of that for me. I drain the pan first, then reinstall the plug. Then I remove the filter with the catch pan underneath.
Old Dec 20, 2005 | 01:24 AM
go_racing84's Avatar
go_racing84
I shove the pan and a 4x4 hunk of wood up on top of the track bar and drag link, drain it through the plug, and then do the filter change from on top (drop the old filter in to the pan, put the new filter on from above).
Old Dec 20, 2005 | 08:12 PM
GreenSubmarine's Avatar
GreenSubmarine
I found a large angled plastic funnel that I can jam between the block and axle housing to catch the oil. I hose clamped a piece of heater hose about 16-18 inches long that I can put over into the drain bucket. No more PITA filter changes. And like roush said, lifting the truck made it a little easier too.
HuntinBronc
1978 - 1996 Big Bronco
Feb 2, 2016 04:25 PM
treehugger49
All Things Towing
18
Mar 14, 2015 08:39 AM
nikmish
Jul 1, 2011 01:32 PM
FlameNSky
Feb 20, 2010 09:30 AM
cclgeo
Modular V10 (6.8l)
15
Aug 21, 2007 09:27 PM
