Data Port Location?
Old Dec 17, 2005 | 05:31 AM
XylemXorro's Avatar
XylemXorro
Data Port Location?
I was going to list this in the electrical forum, but thought I'd start here first. I have an '88 F450 7.3 and wanted to read the codes, but I cannot find the data port. I have looked everywhere! I was told it was under the hood on the passengers side-no luck! Anyone got a clue?
Old Dec 17, 2005 | 12:08 PM
Spectramac's Avatar
Spectramac
What trans do you have? You may not even have one. The engine won't give codes (no computer).
Old Dec 17, 2005 | 06:06 PM
ncfirefighter46's Avatar
ncfirefighter46
if i am right i think 96 and up have the computers for the obd2 to read the codes,
Old Dec 17, 2005 | 06:24 PM
XylemXorro's Avatar
XylemXorro
How would I go about getting the check engine light to go off then???
Old Dec 17, 2005 | 08:53 PM
PLC7.3's Avatar
PLC7.3
Test connectors should be in engine bay on the drivers side near the hood hinge, there should be a six pin and a single pin connector. Have you tried disconnecting the batteries for 10 minutes.
Old Dec 17, 2005 | 10:13 PM
Spectramac's Avatar
Spectramac
Hmm, unless you have an overdrive automatic I wouldn't expect to see any kind of computer on that truck. But if it really has an orange check engine light... Do what PLC says.
Fill in your location and signature with info on your truck. It helps us all know where we're talking to and answers questions about your truck. Like if you were from western WA I could hook a scanner up on your rig.
Old Dec 18, 2005 | 11:46 AM
bilder12's Avatar
bilder12
I do believe the only way you could have a computer controlled anything is if someone added an e 40 D trans to the truck .. possibly one of the first ones to have it and your state titles it as 88 and not 89.
Old Dec 18, 2005 | 05:52 PM
XylemXorro's Avatar
XylemXorro
ok. ok. Sorry for leaving everyone hangin'. The trannys manual, and I guess I'll just disconnect the batteries. Thanks to all!
Old Dec 18, 2005 | 06:13 PM
dieself250's Avatar
dieself250
I think there are only 2 things that will turn on the engine light, no oil pressure less then 7 psi and engine over heat at 244 deg. do you still have the factory oil pressure sender hooked up
Old Dec 20, 2005 | 04:22 AM
XylemXorro's Avatar
XylemXorro
Well, if I knew where it was at I could look and see. Unfortunately, I cannot find a book on this thing anywhere...
Old Dec 20, 2005 | 10:31 AM
Spectramac's Avatar
Spectramac
So is this the red 'engine' light or an orange 'check engine' light? I'm kinda thinking the first one. You might try unplugging the overheat sender on the front lower corner of the driver's side head. Just one wire and it pulls off. Other than that you'll have to look way in the back for the oil pressure switch. It's back behind the intake manifold. I wouldn't suspect it unless your oil pressure is acting up too.
Old Dec 20, 2005 | 01:10 PM
PLC7.3's Avatar
PLC7.3
Check wires on the engine harness for worn shield and grounding out.......
Old Dec 21, 2005 | 04:43 AM
XylemXorro's Avatar
XylemXorro
Good deal. I'll look into it when I get the chance. Right now my five month old twins are ruling the household ...
Capone99
Sep 17, 2011 09:31 AM
mustang_gt_350
Apr 13, 2011 12:04 AM
gopher2
Oct 10, 2009 01:59 PM
Kuskoal
Aug 11, 2009 04:20 PM
cfies
Modular V10 (6.8l)
May 17, 2006 05:13 PM
