Sponsored by: Innova
help
Old Dec 16, 2005 | 10:22 PM
1986_F150's Avatar
1986_F150
help
i bought all the hook up kits for the factory harness and when i turn on my light the radio cuts off i got a pioneer 1600 with a sony 500 watt amp and two 10" pioneer premiers does anyone know what could be hooked up wrong for the radion to cut off when i turn my lights on
Old Dec 17, 2005 | 12:26 AM
IPACA9's Avatar
IPACA9
have your grounded your radio to the dimmer wire? This wire will show ground when the lights are off but then goes to 12volts when you turn the lights on and adjust the dimmer.
Old Dec 17, 2005 | 02:22 PM
RomerB2's Avatar
RomerB2
Sounds like something's shorting out like KC said.
Old Dec 17, 2005 | 02:57 PM
IPACA9's Avatar
IPACA9
I've seen this many many times from customers bringing me thier car after thier buddy installed the radio for them.
Old Dec 17, 2005 | 09:14 PM
1986_F150's Avatar
1986_F150
is the blue wire on the radio for the remote wire for the amp or should i hook that up witht he acc wire
Old Dec 17, 2005 | 09:20 PM
RomerB2's Avatar
RomerB2
I think blue is actually the power antenna, but I'm not 100% sure on that one, it's either that or you remote wire.. either way it should turn the amp on, but if it's power antenna.. it could turn your amp off if you put in a CD.
Old Dec 17, 2005 | 09:24 PM
1986_F150's Avatar
1986_F150
it has a tag on it that says remote control system
tjc transport
Nov 28, 2014 08:41 AM
chamblizi
Nov 4, 2012 06:51 PM
Armalite
Oct 13, 2012 09:06 AM
78F150XLT
39
Jun 21, 2007 12:14 AM
Red_EB_Bronco
Apr 11, 2003 09:34 PM
