ignition lock problem ??
Old Dec 16, 2005 | 03:28 PM
f250newbie's Avatar
f250newbie
i bought a 90 f-250 last week and im having a problem with the ignition lock i think. when i start it sometimes the dash lights,radio,and heater dont come on until i hit the top of the steering column a couple times with my hand then everything comes on and works fine. it will still start but everything else inside wont work until i hit it. seems like a loose electrical connection.
is this the ignition lock itself or just a loose electrical connection to it ??
and is the ignition lock pretty easy to change and will a need any special tools like a puller or something to remove it ??
thanks, never changed one before
Old Dec 16, 2005 | 05:21 PM
quicklook2's Avatar
quicklook2
the lock is easy but the ignition switch itself is furthur down the column and is attached to the lock by an actuator rod.
do a search on this and you will find a lot of info,
Old Dec 16, 2005 | 06:55 PM
alz's Avatar
alz
I had a very similar problem on my 95 F150. I replaced the ign. switch and thought I had it beat. A couple days later it returned. Check your battery connections and the connections at the starter selinoid on the firewall. I'm still waiting for it to happen again, but it's holding out for about two weeks now.
Old Dec 26, 2005 | 02:43 PM
AzMedic25's Avatar
AzMedic25
I have similar issues with my 1994 F-350. The internal moving parts in the steering column were sticking. Mine is corrected with a slight turn of the switch back towards off when it sticks. If yours is sticking all the time you might need to use some lubricant inside the column.
Old Dec 26, 2005 | 06:57 PM
f250newbie's Avatar
f250newbie
ill try that. it starts up fine everytime just all the accessories dont come on till i pound on top of the steering column a couple times then everything is good to go.
was yours doing this also or would the lock not turn at all?
Old Dec 27, 2005 | 11:53 AM
AzMedic25's Avatar
AzMedic25
Thge lock turned fine, it occasionally would stick and no radio, heater, ect. I just turn the key back towards off just a little and all returned to normal.
You might need to spray some graphite in the ignition switch inside the column.
Old Dec 27, 2005 | 12:05 PM
f250newbie's Avatar
f250newbie
thanks,ill try that
Donald Edmonton
2009 - 2014 F150
16
Nov 7, 2012 11:24 AM
lharker
Oct 31, 2011 08:46 PM
landscaper
Mar 20, 2009 10:53 AM
F150Terry
Nov 10, 2008 06:15 PM
