91 f250 dash lights
Old Nov 10, 2010 | 08:47 PM
steedracer's Avatar
steedracer
Trailering
91 f250 dash lights
My dash lights have gone out on my truck and was wondering anyone could help? I checked the fuse and it was ok. I checked to see if there was any power to the fuse and there was none. Does the dash light get there power to the fuse from the head light switch or from somewhere else? does any one know where I can download a wiring diagram for a 91 f250
Old Nov 11, 2010 | 09:26 AM
Franklin2's Avatar
Franklin2
The dash light fuse does get it's power from the headlight switch. What I would do first is take the headlight **** and twist it all the way to the left. See if the dash lights light in a certain spot. All the way over and they will go out and the domelight will come on.
If they do light just in that one spot, then the dimmer resistor in the headlight switch has burned out.
Old Nov 11, 2010 | 10:31 PM
steedracer's Avatar
steedracer
Trailering
I found out that I had a blown fuse for the exterior lights( marker lights, tail lights and side lights ). This fuse feeds power to the dash light fuse. Once I noticed that these lights were not working also and replaced that fuse everything was back to normal .Thanks
cghstrojan08
29
Oct 15, 2024 09:14 PM
DesertZuki
May 15, 2015 11:03 PM
Vinford
20
Feb 4, 2013 08:32 AM
norts1138
17
Nov 14, 2012 08:59 PM
steedracer
Nov 12, 2010 08:03 AM
