What is the payback?
Old Dec 22, 2001 | 09:02 PM
deltafordman's Avatar
deltafordman
Old Jan 1, 2002 | 12:23 PM
gr8199's Avatar
gr8199
Hi all,
What can I expect in the way of performance & MPG gain by replacing the points with electronic ignition on a 1973 F250 w/360?
Any insight from anyone who has done this will be appreciated.
Thanks,
Don
Happy New Year
Dang I got a hangover
Old Jan 1, 2002 | 04:11 PM
hartmark's Avatar
hartmark
I just replaced the points in my 1974 360 with the pertronix ignitor and pertronix coil. I haven't noticed a whole lot of difference, other than it seems to run smoother. I haven't run it enough to figure out if there is a change in mileage. I just like that I will never have to mess with points.
I had a problem installing the system, in that you have to bypass the resistance wire to install the ignitor. I didn't want to pull apart the dash to find the end of the resistance wire so I found a wire (green with red tracer) that it seemed (from the wiring diagram) was only powered in the run position. There is a problem somewhere in the system (maybe at the voltage regulator) that is supplying power to this wire whenever the alternator is turning. The engine, therefore, runs even after I turn the key off. I really need to figure out where the problem is.
Other than the run on problem, the Pertronix kit is working great.
Mark
Old Jan 1, 2002 | 06:47 PM
jbhf250's Avatar
jbhf250
DITO on the above except i did not have the resistor wire problem.
The module has been in for 2 1/2 yrs now and no problems.
Interesting thing I carry a set of points in the glove box just in case BUT I have since loaned the points to 2 others to get home because there point systems gave up
I wonder what a Pertronix distributor ship costs??
Hey Ken could you sell them here!!
__JOHN__ô¿õ
1972 F-250
ICQ# 6030753
Old Jan 2, 2002 | 08:39 AM
hartmark's Avatar
hartmark
Oh yeah, I forgot to say that one of the cheapest prices I found for the Pertronix is at: http://www.vamustang.com/ignitors.htm
There was one other cheaper place, but since I live close to the above store I saved on shipping, and had a great drive through the mountains of VA.
Mark
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
