Sponsored by: Innova
Need help picking an alarm!!!
Old Dec 15, 2005 | 10:58 PM
bigmike09's Avatar
bigmike09
Well guys I am looking to get an alarm on my 98 f-150.Can yall tell me which ones are good and which ones to watch out for.I am basically looking for one that if will chirp or go off if you bump it hard enough.I have seen some that you have to actually open the door to set it off.I do not mind paying for a good one.Thanks for all of your help.
Old Dec 16, 2005 | 02:08 AM
chiahunw's Avatar
chiahunw
Look for the ones made by DEI (ie. Viper and Python). The most basic alarm systems made by DEI all have adjustable 2-stage shock sensor, can be tie into door latch sensors, keyless entry, and more. I had the Viper basic alarm system installed on my last car (cost $200 installed 6 years ago). Now I have the Viper 2-way alarm with remote start installed on my current truck (cost $500 installed 1 year ago). No problem so far.
Get the one that fits your budget and needs. You should go to your local car stereo stores and car windows tinting stores. They should have alarm installer. Also, ask around and see where other people got their alarm installed and how they like it.
Good luck.
Old Dec 16, 2005 | 02:49 AM
RomerB2's Avatar
RomerB2
If you're into the DIY thing, you could look at asianwolf.com.. I've heard a few good things and none bad, but it's up to you.
Old Dec 16, 2005 | 04:16 AM
Bargod's Avatar
Bargod
I would go with a G5 system from Clifford. They offer three different models based on what you need and what you want to spend.
http://www.clifford.com/g5/sec/default.asp#arrow5
Old Dec 16, 2005 | 03:34 PM
Percys Armory's Avatar
Percys Armory
Most alarms don't prove much. ONly reason Id get one is to control the radio, windows and remote start
Old Dec 16, 2005 | 05:02 PM
fordboy_52's Avatar
fordboy_52
not true. some alarms come with a remote that can tell you if someone try's to so much s open the door. up to something of like 5 miles away
Matt
Old Dec 16, 2005 | 06:45 PM
Percys Armory
Matt
Do they rteally have that distance. and if you are five miles away what are you going to do?
Old Dec 17, 2005 | 01:46 AM
RomerB2's Avatar
RomerB2
There are also alarms that you have to punch in a code in order to get the thing to start, then there's one's with cameras in them that send the picture of the purpetrator to your remote (since some are now LCD) up to 5 miles away.
Old Dec 17, 2005 | 07:12 AM
rebocardo's Avatar
rebocardo
Some decent alarms www.autoloc.com. The directions are very good and the harnesses are color coded and the relays standard iso that are easily replaced on the alarm I bought.
Old Dec 17, 2005 | 08:39 AM
Percys Armory
I had one that required the code. Has anyone actually had experiance with the 5 muile remote?
Old Dec 17, 2005 | 02:16 PM
RomerB2's Avatar
RomerB2
I'm getting the 5 mile one for Christmas
Mine comes with 2 remotes, one is LCD, it comes with the keypad but I don't think I want it right now. It also has start function and when someone gets close to my truck it'll roll up the windows if they're down. I can roll up or down the windows from my keyfob. And mine is compatible with the hidden camera that sends the persons picture to my LCD remote, but I'd have to buy that seperately (don't want it really).
Old Dec 17, 2005 | 03:15 PM
Percys Armory
who makes it?
Old Dec 17, 2005 | 09:21 PM
RomerB2's Avatar
RomerB2
I think it's an asian wolf.. not 100% sure on that one though.
Old Dec 18, 2005 | 08:03 PM
bigmike09's Avatar
bigmike09
Thanks guys for all of your help. I will check these out.
Old Dec 18, 2005 | 09:58 PM
IPACA9's Avatar
IPACA9
Pssst! Hey you should check out the Code Alarms. Great units.
