Spark plug ?'s
Old Dec 15, 2005 | 01:01 PM
Icicle's Avatar
Icicle
Spark plug ?'s
Correct reach and plug diameter for a stock 302 head? (1982)
Old Dec 16, 2005 | 08:49 AM
TigerDan's Avatar
TigerDan
In 1975 Ford went from 18mm to 14mm taper-fit plugs...so '82 heads would be the latter. Autolite number would be 25. 14mm, .460" reach, 5/8" hex, tapered seat.
Old Dec 16, 2005 | 05:15 PM
Icicle's Avatar
Icicle
Thanks Dan, I ended up figuring it out with googles help, I knew the autolite number, but couldnt find any technical data on their website.
At any rate, thanks!
Old Dec 17, 2005 | 02:42 PM
Customcab's Avatar
Customcab
Well tell me this I got an 76 302 Truck motor and I'm running Autolite 45's at 0.44 plug gap; they screw into the heads real easy and only have to use a socket about an 1/4 turn to be snug. I'm I running the wrong plugs? Engine data is 302cid; bore 60 over 10:5 to 1 with a mid cam.
Mitch
Old Dec 17, 2005 | 04:25 PM
Icicle's Avatar
Icicle
no, thats the right plug for a 76, perhaps someone at one point did use the wrong plugs though and your threads are filled with Carbon
mrad
Modular V10 (6.8l)
Apr 19, 2012 09:56 AM
alanscott
Aug 12, 2002 02:26 PM
disappointed
Mar 26, 2002 03:40 PM
beratte
1978 - 1996 Big Bronco
Feb 15, 2002 02:14 AM
cyberbyrd
Feb 3, 2002 04:42 PM
