351 throttle body removal
Old Dec 15, 2005 | 11:53 AM
mike schubert's Avatar
mike schubert
Try not to cringe but I need to explain to our maintenance man how to remove the throttle body from our F-150 van. The tps is bad and I understand that removing the tb is the only way to go. Does anyone have a diagram or picture or something that i could give to him? I don't have time to remove it myself and I'm scared to let him try it without a clear explanation, ie. picture.
Thanks for the help.
Mike
Old Dec 15, 2005 | 01:06 PM
EPNCSU2006's Avatar
EPNCSU2006
It is pretty self-explanatory once you see it. There are four bolts on the corners that must be removed. Be sure to have a new gasket on hand for when the throttle body is reinstalled. Here is a picture I found, note the bolt holes in the corners of the flat part...
http://69.20.110.81/images/products/...mages/3837.jpg
Old Dec 15, 2005 | 01:24 PM
mike schubert
Smile
Thank you very much. That is exactly what I needed.
Merry Christmas
Mike
Old Dec 15, 2005 | 02:24 PM
s8whiskey's Avatar
s8whiskey
Dont over tighten the bolt I might have slightly done this and had to tap new ones. 12 to 15 ft/lb. on your torq wrench and you will be good to go.
Mike Mckenna
Apr 7, 2012 12:55 PM
X_Hemi_Guy
Dec 21, 2009 10:32 AM
dfishrmn88
Modular V8 (4.6L, 5.4L)
Nov 30, 2008 07:33 PM
mike L
Jun 17, 2006 06:47 AM
mike3000
Jan 5, 2006 03:42 PM
