Had the first major snowfall a week ago and kicked it into 4 wheel for the first time in awhile and noticed a few things that I do not recall happening before.
After engaging and driving it is rather noisy. Can't tell if it is grinding or what. Could it just need a lube job or could it be something worse? The hubs engage quickly yet do not like to disengage unless I drive backwards. This never use to be a problem. (I do not recall if they disengaged before without help)
When driving at medium speeds (45 ish) the truck pulls to one side or the other quickly then returns to normal.
It is not very noticable but if I slow down to 10 ish you can really feel it pull.
Does this sound like an allignment issue?
It drives rather straight when not in 4 wheel.
It has been awhile since I used the 4WD so I do not remeber these issues.
Almost sounds like one of the hubs is intermittently disengaging.
What year is your truck? If I were to guess, I'd say it's a '98-'00 with the pulse vacuum hublocks (PVH).This kind of 4x4 system can be identified by the black plastic used on the outer part of the front hubs with a little screen in the center.
The PVH vacuum system is far from 100% reliable, which translates into engagement/disengagement issues. Another quirk is that, if the PVH system is not used often, it can get noisy.
Sorry, i guess I forgot to put in the year of the truck. It is a 2000 4wd XLT
I never thought of it but I guess that the pulling could be caused by the hub disengaging.
Is there a way that you know of that I could test this?
You could start by looking over the vacuum lines, they run from the hubs back to the PVH solenoid, and then from there to the vacuum reservoir tank. If you take the front tires off and then remove the passenger side splash shield you will have access to pretty much everything. Check the connections, look for kinks in the lines, etc. If you want to get a little more detailed in your diagnosis you can follow this:
