4WD Issues
Old Dec 15, 2005 | 07:50 AM
Jbum123's Avatar
Jbum123
4WD Issues
Had the first major snowfall a week ago and kicked it into 4 wheel for the first time in awhile and noticed a few things that I do not recall happening before.
After engaging and driving it is rather noisy. Can't tell if it is grinding or what. Could it just need a lube job or could it be something worse? The hubs engage quickly yet do not like to disengage unless I drive backwards. This never use to be a problem. (I do not recall if they disengaged before without help)
When driving at medium speeds (45 ish) the truck pulls to one side or the other quickly then returns to normal.
It is not very noticable but if I slow down to 10 ish you can really feel it pull.
Does this sound like an allignment issue?
It drives rather straight when not in 4 wheel.
It has been awhile since I used the 4WD so I do not remeber these issues.
Thanks!
Jeff
Old Dec 15, 2005 | 11:21 AM
Rockledge's Avatar
Rockledge
Almost sounds like one of the hubs is intermittently disengaging.
What year is your truck? If I were to guess, I'd say it's a '98-'00 with the pulse vacuum hublocks (PVH).This kind of 4x4 system can be identified by the black plastic used on the outer part of the front hubs with a little screen in the center.
The PVH vacuum system is far from 100% reliable, which translates into engagement/disengagement issues. Another quirk is that, if the PVH system is not used often, it can get noisy.
Old Dec 15, 2005 | 01:14 PM
rangerxlt02's Avatar
rangerxlt02
I just noticed the same thing on my 02 Ranger. Have to backup in order for the 4WD to disengage.
If I don't back up, then it's noisy (can feel a shudder in the driveline).
very odd as it just started on mine as well. I do use my 4WD from time to time as to avoid these issues.
Old Dec 15, 2005 | 02:30 PM
Jbum123's Avatar
Jbum123
Sorry, i guess I forgot to put in the year of the truck. It is a 2000 4wd XLT
I never thought of it but I guess that the pulling could be caused by the hub disengaging.
Is there a way that you know of that I could test this?
Thanks!
Old Dec 15, 2005 | 05:56 PM
Rockledge's Avatar
Rockledge
You could start by looking over the vacuum lines, they run from the hubs back to the PVH solenoid, and then from there to the vacuum reservoir tank. If you take the front tires off and then remove the passenger side splash shield you will have access to pretty much everything. Check the connections, look for kinks in the lines, etc. If you want to get a little more detailed in your diagnosis you can follow this:
PULSE VACUUM HUBLOCKS - Diagnosis & Testing
blazerf250
1997 - 2003 F150
Jan 12, 2014 07:56 PM
Beeler
31
Dec 27, 2012 10:20 AM
SailCO26
25
Jun 4, 2010 09:41 AM
derekmj64
May 17, 2010 05:44 AM
BroncoPimp94
Feb 9, 2010 06:45 PM
