motor id
Old Dec 14, 2005 | 11:44 PM
paul j's Avatar
paul j
Question motor id
can anybody tell what the numbers mean for my engine d4de-6015-ba and what the ba stands for
also what can i do to encrease the hp
i want to put it in my 66 short bed project truck
i would app. any help offerd this is my first project and i want to do it right
thanx paul j
Old Dec 14, 2005 | 11:48 PM
Racerguy's Avatar
Racerguy
Hi Paul and welcome to FTE
What sort of engine is it? We can move your question to a more specialized forum for you.
Old Dec 14, 2005 | 11:49 PM
paul j's Avatar
paul j
it is ford 302
thanx paul
Old Dec 15, 2005 | 12:27 AM
TigerDan's Avatar
TigerDan
Paul, read my answer to this question in this thread:
https://www.ford-trucks.com/forums/s...d.php?t=439424
The main difference here is that yours has a D in the third position of the first group, in that case it means it was originally designed for the Falcon. Doesn't mean that's what it came in though...just the way Ford does it.
When it comes to increasing the power, it really depends on your goals and your budget. Trucks need torque, and they need it down low in the RPM range so you have to choose a cam accordingly. Likewise, a dual-plane intake made to work from idle to about 4500-5000 is better than an open plenum, and long tube headers will all work together to keep your power where you want it.
Are aftermarket heads in the budget? There are good iron heads to be found or you could step up to aluminum. Converting to EFI isn't as hard as it sounds either, there are wiring kits available that make it do-able.
Don't forget the ignition. There are so many decent aftermarket ignitions on the market that I hate to recommend one in particular, but the D.U.I. ignotion is a simple one-wire hookup, if you can stand the thought of having what's basically a Chevy distributor in your Ford!
Of course, there are also stroker kits available...
These are just some basics to get you thinking, and maybe bring up some other questions for us. Some of the other guys will surely stop by with some further advice and recommendations, among which will most certainly be stepping up to a 351W. That's something else to consider. Some of us are die-hard 289-302 guys and some will accept nothing less than a 351W. I get the feeling that this is an engine that you've come across and are set on using for your project, so it's really up to you. Whatever you decide, we're here to help!
PAUL W BEAUCHEMIN
Dec 14, 2014 11:56 AM
pjk212
Nov 20, 2008 10:58 PM
Paul Therriault
27
May 23, 2006 09:57 PM
sneak
General Automotive Discussion
13
Feb 3, 2005 11:53 PM
