1978 - 1996 Big Bronco
Exhausting Question
Old Dec 14, 2005 | 03:21 PM
Corey872's Avatar
Corey872
Exhausting Question
Well, the old Bronc seems to have developed an exhaust leak at the joint between the exhaust manifold and the "Y" pipe. I thought the gasket may have blown so I pulled the bolts off and looked at the joint. I don't see any remnants of a gasket at all.
Does anyone know for sure if there is supposed to be a graphite dounut gasket between the manifold and the "Y" pipe? or is this supposed to be a metal-to-metal fit? This is a 1993 5.8L if that makes a difference.
Thanks,
Corey
Old Dec 14, 2005 | 05:38 PM
slickerthanyou's Avatar
slickerthanyou
It's a ball/socket fit. The best IMO. Needs tightened. No gasket at all.
Old Dec 14, 2005 | 06:13 PM
Corey872's Avatar
Corey872
Great! I'll put a couple of extra cranks on the bolts and see how it works.
Thanks!
Corey
Old Dec 14, 2005 | 06:14 PM
greystreak92's Avatar
greystreak92
Yeah, STY, you got it... no gasket ever in there. If the leak has been present for a while and soot has built up around the leak point, it may help to drop the Y-pipe far enough to scrub the soot and carbon away from the mating surfaces to achieve a better seal when you tighten it back up.
Dean06919
Jul 22, 2015 11:16 AM
snowmobile mike
Sep 22, 2012 01:54 PM
Gary Lewis
Nov 21, 2010 03:48 PM
mike L
Jun 29, 2006 08:02 PM
thoseapples
Exhaust Systems
Feb 21, 2002 07:38 PM
