Rear upper shock mounts.
Old Dec 14, 2005 | 12:36 PM
boilrman's Avatar
boilrman
I am restoring a truck for a friend and am in need of the rear upper shock mount towers. Anybody got any? Any help would be appreciated. The truck is a 78 F-150 4X4.
Thanks,
Chad
Old Dec 14, 2005 | 12:43 PM
77300i6's Avatar
77300i6
Try you local neighborhood Ford dealer. ~$45 ea.
Old Dec 14, 2005 | 06:37 PM
thesprocket26's Avatar
thesprocket26
Or you can make your own and use some high grade bolts. Might be cheaper but not original.
Old Dec 14, 2005 | 08:23 PM
garypettengill's Avatar
garypettengill
There is a set on ebay right now. Item number: 8022830854 They are under 78-79 Bronco but they're the same.
Old Dec 14, 2005 | 08:41 PM
Xowner's Avatar
Xowner
i have a set id take 35 shiped for those one he listed just ended
also a question are 3/4 ton upper frame shock mounts diffrent?
Old Dec 14, 2005 | 10:38 PM
whalerron's Avatar
whalerron
Those parts are still available from Ford. If you do a search in this forum for rear shock mounts, you should be able to find the part numbers.
Old Dec 15, 2005 | 12:05 PM
busted knuckle's Avatar
busted knuckle
i made mine with 1/4in plate steel and welded them to the frame. it works. i like it. but not original i stated before.
Old Dec 15, 2005 | 02:31 PM
boilrman's Avatar
boilrman
rear upper shock towers
Thanks for all the help guys. I did find my local NAPA can order them. Part number is D8TZ18169A if anybody else is interested.
Old Jan 14, 2006 | 12:14 PM
TruckDrivinFool's Avatar
TruckDrivinFool
My local NAPA says that number is a ford number but they don't match anything. Anybody know if a later year mounts will work? I've looked in the junkyard and they look similar but would require changing to the right style of shock end.
Last edited by TruckDrivinFool; Jan 14, 2006 at 12:28 PM. Reason: Made the phone call
Old Jan 14, 2006 | 12:27 PM
boilrman's Avatar
boilrman
Originally Posted by TruckDrivinFool
Is that a NAPA number or a different makers number I can't find it on NAPA's web site.
That is an actual part number. Guessing it is Ford. If you call your NAPA store they can look up a price. My local NAPA says $53 or something like that.
Old Jan 14, 2006 | 12:30 PM
TruckDrivinFool
WOW quick reply while I got smart enough to call them and edit my post.
Old Jan 15, 2006 | 12:32 PM
teederj2002's Avatar
teederj2002
I went to the Ford dealership and got the mounts for a 80's f 150. They went right in place and I just had to switch to double hoop shocks.
Old Jan 16, 2006 | 08:46 AM
TruckDrivinFool
Thanks I've got whats left of the old one off so I guess I'll make a trip dow to Ford and see if they can find me something.
Old Jan 16, 2006 | 08:34 PM
whalerron's Avatar
whalerron
In 2001, the right mount on my 77 rusted off at the frame like yours did. I went to the local ford dealer and got a brand new one for $38. It was an in stock part and the parts guy said it's the same part as is used on newer model trucks. As stated above, the part number is
D8TZ-18169-A Bracket Rear S
The only hard part about replacing this was grinding off the rivets. I just used grade 8 bolts to mount the new part to the frame.
-Ron
Old Jan 18, 2006 | 02:56 PM
TruckDrivinFool
Ok I got one now that I convinced the parts guy at the local Ford dealer that I was looking for a left rear shock mount and not a left front spring mount. Thanks guys
nmlongbow
Nov 19, 2017 01:06 PM
D-rat
May 16, 2017 07:48 PM
jamieson48
May 7, 2012 02:58 PM
bserventi
Apr 9, 2009 10:05 PM
fatfenders
Aug 13, 2002 12:14 PM
