C6 Tranny questions
Old Dec 14, 2005 | 08:53 AM
69crewcab's Avatar
69crewcab
C6 Tranny questions
Group
i need a Tranny (c6) for my 78 4x4 crewcab, the one in it now slips horribly.
I would like to be able to rebuild a c6 this winter and be able to swap them
come spring time. Can i pull a C6 from a bronco? Or how about a 2wd version?
Joe
Old Dec 14, 2005 | 09:03 AM
jmalecek's Avatar
jmalecek
A c6 from a bronco would work if it's for the same engine series. You may have to swap out the transfer cases depending on what year the donor trannie comes from.
Jamie
Old Dec 14, 2005 | 09:15 AM
69crewcab's Avatar
69crewcab
why the transfer case too??
joe
Old Dec 14, 2005 | 09:53 AM
mark a.'s Avatar
mark a.
There are 2 different tail shaft lengths as far as the 4x4's go. Just make sure you have the right one. As for car c6's, anyone will work. Just make sure it has the bolt holes for the neutral/reverse switch, some cases don't have them. you'll also have to put the right length 4x4 tail shaft in it when you rebuild it. The car tail shafts won't work.
Old Dec 14, 2005 | 10:02 AM
69crewcab's Avatar
69crewcab
Boy
ford couldn't make it wasy could they
Now i need to measure tailshaft lengths in the cold
Old Dec 14, 2005 | 10:30 AM
Mike G's Avatar
Mike G
Have you attempted to adjust out some of the slipping that you are experiencing? To be honest with you, rebuilding one takes about two days, less if you have all the parts and a warm place to work...
--Mike
Old Dec 14, 2005 | 12:18 PM
69crewcab's Avatar
69crewcab
Mike
adjusting the bands?? Might be the trick? Or is there more
Old Dec 14, 2005 | 12:54 PM
ivanribic's Avatar
ivanribic
If you have everything ready to go you can take the tailshaft out of your old tranny and swap it into the new tranny. This is a couple hour project that's not terribly difficult to do but you will have to disassemble the new tranny to make it happen. I had to do this on my truck last summer as the tailshaft on the new tranny was too short.
Old Dec 15, 2005 | 10:32 AM
Mike G's Avatar
Mike G
Originally Posted by 69crewcab
Mike
That was my thought... Loosen the hold down nut, turn in the treaded center screw a 1/2 turn (at a time), lock down the nut and take her for a spin. You may also look at the vacuum lines to your modulator (back of tranny, lower passenger side) to see that the lines are toast and you're loosing vacuum.
--Mike
Old Dec 15, 2005 | 04:22 PM
69crewcab's Avatar
69crewcab
Mike
thanks for the tips...The Vacuum line was toast, and I'm back in buisness..
Thanks again!
Pickupmanx2
Jul 19, 2010 05:21 PM
AndysFords
Apr 2, 2006 08:40 PM
blueovalman
Feb 7, 2006 11:07 PM
jds1971
Jul 24, 2003 06:58 AM
69crewcab
Nov 12, 2002 11:31 AM
