Okay I just got my truck back from sand blasting and primer. Will have pics tomorrrow. On a budget what do I do next... other then body work. Where do I start?
It looks like you got yourself a great start! I like to get the sheet metal in very good prime before I start the chassis. The chassis is the most fun so I do that after I have worked all the sheet metal into good prime. Good prime to me means ready to start block sanding. Too many times, guys run out of gas after the chassis is done and the bodywork becomes overwhelming. Stay with the forum it will help keep you going.
Good luck!
Are you going back stock or custom? That makes some difference in the sequence of things.
There are several things that can be done without spending a lot of money.
1. Make a written plan of what you are going to try to accomplish.
1. Fit the doors, probably need to replace the hinge pins
2. Do rust repair: cut out rusted areas and replace with new metal. Start with the floor boards.
3. If custom, determine any changes that you are going to make to the dash.
4. If you don't want to do the body work now, work on the chassis.
I always like to do the chassis work first and save the body work for last, but I think it just depends on what you want to work on at the time...
Vern
I agree with this.I just about have my frame finished.I like having the frame painted and looking nice.That gives me motivation to carry on with the rest.
